Originally Posted by 90 GP
Did you loosen the bolt (from the front) where that black wire passes over the bracket where you can see the nut welded on the back? Loosen that bolt and another bolt diagonal to it which is on the lower part of mounting bracket and then pull the pump assembly toward the front of car. The belt should come right off.
Thanks GP,,,,,,,,,,,,I was missing the lower bolt you mention, no wonder it would not budge.
In typical Haynes fashion of course they never mention this bolt in the manual!!!!!!
