How to adjust "sprinklers" in Corolla 2006 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2006, 05:25 PM   #1 (permalink)
View neeco80's Photo Gallery
Canada How to adjust "sprinklers" in Corolla 2006
Hi all,
I'm not sure if this is the right way to call this in english (I'm french Canadian), but I'm wondering how to adjust the "sprinklers" in Corolla 2006 ? (By sprinklers I mean what we use to spread water (or water with anit-freeze in winter) on the windshield) Mine are spreading water too low and this problem is more obvious when it's windy... is it adjustable? If yes, how? Do I have to open the hood and remove the isolation? If yes, how? (there's plastic screws that I tried to remove without success, and don't want to break...)
Thanks for your advices,
Nico
neeco80 is offline   Reply With Quote
Old 11-29-2006, 07:01 PM   #2 (permalink)
The Original Mofo
View HL2k's Photo Gallery
Windshield washer sprayers
Pissers
Whatever
but not sprinklers, they do not sprinkle, they SPRAAAAAAAY, when you urinate do you sprinkle? no you SPRAAAAAAAAAAY or you PIIIIIIISSSSSSSSSSSSS ok I'm done
anyways not sure about the 06 Rolla, but on every other car I've owned I've just used a small pin to angle them myself, then have someone hit the PISSER button so that it sprays
you do not need to open the hood look at the individual pisser (posting diagram!)
__________
[ (o) (o) ]
thats approx what a pisser looks like, two (or three) grey cylinders and a black outer casing. Each of the cylinders have a hole for the liquid to PISS out of, use a pin to angle and adjust this hole, don't pull too hard as the pin can snap, also just go in about 2mm no more as the pisser isn't that long (DIAGRAM)
(o)==)=====
the o is the hole
the (o)==) is the length of it
the ===== is the line that connects onto it from within
since the outer casing is rubber, it will flex somewhat, but make sure you test after you adjust, or you may be cleaning off the guy's windshield behind you
1990 Celica GT (Garage/unfit)
1991 Toyota Corolla Wagon 4wd (Sold Feb08)
1991 4Runner SR5 V6 4WD (Sold May07)
1990 Corolla Sedan (Tboned+Writtenoff Oct06)
2005 Echo (Twisted the frame+Writtenoff Jan05)
HL2k is offline   Reply With Quote
Old 11-29-2006, 07:19 PM   #3 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by neeco80
Hi all,
Nico
We call them window sprayers/washers...
I just use a push pin...The kind with the plastic on it to hold notes and things up...saves on the fingers and is a little stronger
Though I would think that with all the different type tools out there they do have a specific tool just to adjust your "sprinkles"
~Radd
Raddman is offline   Reply With Quote
Old 11-30-2006, 07:32 AM   #4 (permalink)
All right I get it, HL2k, I won't call it SPRINKLERS but PISSER.... I mean, windshield washer sprayers Anyway, on Corolla 2006, it's not designed the same way as older models,
let say like Corolla 2003. On those models it's spraying in a straight line, but not on 2006 models. There's only one small rectangle hole on half of the area (other half is closed), no way to put a push pin like you suggested, Raddman... any suggestions?
Thanks again,
Nico
Old 11-30-2006, 09:41 AM   #5 (permalink)
Registered User
Raddman's Avatar
USA
Thanks again,
Nico
Yeah I have an 03 and it has 3 pisser holes on each sprayer and using a pin its easy to adjust them I would just call Toyota parts or service and ask them...They probably have as I said a special tool you are forced to buy, but I would think they would do it as a courtesy to you, how much could it cost ...Anyway it won't cost you anything to ask ...Good Luck..
Everyone's 06-07 pissers must be perfect here or someone would know how they are adjusted
~Radd
Old 11-30-2006, 01:44 PM   #6 (permalink)
View tigrpal's Photo Gallery
My '07 owners manual says specifically NOT to push a pin into the sprayers because they could be damaged.
2007 Corolla LE Manual
tigrpal is offline   Reply With Quote
Old 11-30-2006, 02:54 PM   #7 (permalink)
Registered User
Raddman's Avatar
Sooooo....Thats understandable....Then how does your manual say to adjust them
~Radd
Old 11-30-2006, 03:34 PM   #8 (permalink)
The Original Mofo
take it to Toyota
yell and bitch at them say you are all a bunch of bastards and you will pee on their floor unless they meet your demands
at least thats what I'd do, but then I do extreme things like that and not simple questions
Old 11-30-2006, 04:32 PM   #9 (permalink)
~Radd
The manual doesn't say how to adjust them. It says to be careful when waxing to not get wax in the nozzle and to not use a pin to get the wax out. "Take it to your authorized Toyota dealership for repairs." Not very helpful.
Old 11-30-2006, 05:24 PM   #10 (permalink)
View newbie212's Photo Gallery
Originally Posted by HL2k
take it to Toyota
You mean you'll "sprinkle" on their floor!!
newbie212 is offline   Reply With Quote
Old 12-01-2006, 07:09 AM   #11 (permalink)
I guess I will have to visit my Toyota dealer, just feel bad bothering them for something that should be easy! (like taking an appointment to change the wipers, it just feel weird! LOL) But I'm still hoping somebody knows how to do it! ........ Somebody?
Old 12-01-2006, 07:11 AM   #12 (permalink)
The Original Mofo
screw the appt, drive in there, say ok this is stupid, why the hell do I need to bring my car here for you guys to adjust sprinklers, which is something that is adjusted PER THE USER
Old 12-01-2006, 07:28 AM   #13 (permalink)
Just call the toyota service department.. They will be more than glad to help you.. I worked in a service department for 3 years.. Trust me, we've seen stuff worse than this... An old lady came in one day and needed help getting her rear view mirror in the right spot so she could see better..... Don't feel bad..
Old 12-01-2006, 02:06 PM   #14 (permalink)
The Original Mofo
bring a sword
faster service
Old 12-01-2006, 08:34 PM   #15 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I think pretty soon all car manuals will have one page that will say in the middle.
"DO NOT ATTEMPT TO REPAIR, PLEASE SEE AUTHORIZED DEALER"
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
2006 Corolla Double Din Dash kit? Does it Exist? jordanrobbins Audio, Video, and Security - Tech 1 11-29-2006 04:31 PM
Door Control Receiver - 2006 Corolla rrequen Archived Corolla threads 0 04-06-2006 10:37 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Adjust handbrake on 2002 Toyota Corolla dougone Archived Corolla threads 5 09-08-2004 10:52 PM
