first see if you are throwing any codes.....
if not, then i would check the AFM or the TPS...... the TPS is easy.... as most toyota's will still run fine with them disconnected (may run a bit rich)... but if the TPS is connected and reading inaccurately, then it could cause some lag (ie, you hit the gas, the TPS opens, but doesn't respond.... the injectors don't fire as much.... finally the o2 reads lean and the injectors richen it up....)...
same goes with the AFM....and also that the AFM trap door isn't reacting slowly..... if it's sticking (for whatever reason) it will cause airflow to, uh, not flow..... also, if there is a problem with the voltages from the AFM to the ecu, the injectors will react slow and cause problems.....
i have a hard time thinking it would be the throttle cable...... because if he pushes the pedal to the floor, then the steel-braided cable is pulling the tb open..... even if it's frayed it will still pull it open (ie, would stick when you get OFF the gas)..... and if the cable is broken, then the TB wouldn't open at all....
