Disk brake sliding pins 1997 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2006, 07:28 PM   #1 (permalink)
View 93ToyCorolla's Photo Gallery
USA Disk brake sliding pins 1997 Corolla
can someone please explain the function on the brake sliding pins. also if the top one is frozen (rusted) what happens? also the sliding bushing seems to be just on one of the pins, is this correct and why?
Thank You!
93ToyCorolla is offline   Reply With Quote
Old 12-02-2006, 07:45 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Slide bushings enable the floating caliper to center itself so that it can move freely when the piston is operated to clamp on the disk.
your caliper will either be stuck or it will twist when you apply the brakes. (it wont be parallel to the disk)
Both the top and bottom ones are slide bushings.
Old 12-02-2006, 11:49 PM   #3 (permalink)
What is the best lubricant to use on the sliding pins
Old 12-03-2006, 05:10 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
I used rubber grease on mine.
Old 12-03-2006, 10:57 AM   #5 (permalink)
niko3257's Avatar
View niko3257's Photo Gallery
antiseize should work to.
07 CAMRY CE
02 RC51/SP2
niko3257 is offline   Reply With Quote
Old 12-03-2006, 11:45 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
eh? antiseize?
When you grease up the slide bushings, use anything but petroleum based grease, you'll swell the rubbers and they'll get stuck.
Old 12-09-2006, 02:05 PM   #7 (permalink)
View mike-s's Photo Gallery
see this other post.
mike-s is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
93 Corolla Rear Metal Brake Lines postman Archived Corolla threads 4 03-23-2009 11:20 AM
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
New hubs necessary for drum to disk brake conversion? GameDay 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-30-2006 03:35 PM
