rear axle trouble
the other day i've noticed a clicking in the back. i feel the clicking in the brake petal. its frequency is dependant on speed. if i'm going fast the clicking is more frequent and the slower i go the less often i hear a click. i've check the brakes. apon further inspection i noticed a little oil around the rear "chunk". i'm thinking it might be the rear wheel bearings.
what would be the easiest and cheapest way to fix this problem? and if i should replace the entire rear end? could i just do a rear end gts swap (for the lsd)? would i still be able to use rear drums? or would i be forced into changing the brakes to disc and suspension and the like.
...skeetzilla
