Single click from under the hood when throttle is pushed past certain RPM - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2006, 11:02 AM   #1 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Question Single click from under the hood when throttle is pushed past certain RPM
Hey y'all. Just yesterday my car started making this weird noise. When I gently apply throttle, as the engine speed passes 1500 RPM, there is a single click heard from under the passenger side of the hood. If the pedal is released, there is a similar click as the engine speed passes 1500 RPM on the way down. This happens regardless of the car being in gear or not. It only started yesterday, but I'm pretty sure this happens only when the engine is cold, as it goes away after about 10 minutes of driving.
Upon closer inspection the click may be coming from the part of the cruise control that regulates the throttle (I have SCS/Frigette aftermarket cruise control, installed when I got the car 11 years ago, but it still works fine to this day, although I haven't tried it since the clicking started).
Disconnecting some random wires that attach to the cruise control module didn't affect anything. However, I noticed that when I put my weight on or applied some pressure to the body panel shown by the red arrow (top of the passenger fender)(thereby possibly dampening some vibration???) and then modulating the throttle, the clicks stopped.
Anyway what I'm asking is has anyone had this problem before? I'm not 100% sure if its the cruise control or not so is there anything else that could be making this clicking noise?
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 12-05-2006, 10:22 AM   #2 (permalink)
Ghostridin the whip
Update: tried the cruise control at like 30 mph and it works but makes a constant clicking noise while engaged
Old 12-05-2006, 12:52 PM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
my friends truck was doing the same but with toyota cruise control, what we did is try to disconnect the power to the cruise control and bought a new throttle cable to go from the gas pedal straight to the throttle body and that did the trick.... he never uses his cruise anyway.... sounds like the cruise actuator may be going bad.... that is just my two cents on it
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 12-05-2006, 12:53 PM   #4 (permalink)
2005ToyotaCorollaS
lookling at the pic that may be a vacum driven cruise control.... dont know much about those man...
D
Old 12-05-2006, 03:06 PM   #5 (permalink)
Ghostridin the whip
D
Hmm, well with mine there are two cables going to the throttle, one from that cruise contol box and one from the pedal, I guess.
I'm gonna try and see if the company can help me cause I think it may have lifetime warranty.
Carbon Fiber Hood (or anything else) Tutorial *56K friendly (if you can wait hours)* Razo-E Off Topic 16 10-24-2005 05:42 PM
Throttle Body Cleaning nobrainer Camry & Solara Lounge 13 06-29-2005 03:02 PM
www.jtrsport.com - ebay CF hood seller Phi Feedback: Buyers, Sellers, and Vendors 0 10-12-2004 04:09 PM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 09:04 PM
air fuel ratio questions... HPR Archived Corolla threads 12 12-02-2003 07:10 AM
