I think the original question referred to the strut bar that connects the lower control arm to the frame and stabilizes it.
At the front of the rod, are 2 triangular shaped rubber isolators on each side and through them is a steel collar. There is a 22mm
nut that is torqued to 80 ft-lbs on the front.
If the bar is loose it could cause the clanging sound. They should be replaced if they are worn because they affect your wheel alignment.
Hemi3TC
Originally posted by martiniracing
i just sent you pm... anyway, i think the napa sway bar links are universal for all 80's toyota(s) (corollas)
[i]
front stabalizer arm bushings
On the drivers side they are very warn. From the side they look more like a triangle than a square. few questions:
1. would this cause a clanging noise while driving that dissapears while turning.
2. should I get better quality bushings than those from the dealer which are only $26. I'm not planning to be doing any drifting with this car.
'87 Corolla GT-S hb
The joys of owning a 16yr old car.
