2001 Corolla, Auto/Manual Conversion and Lots of other Goodies *PICS* - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2006, 10:12 PM   #1 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Jerry decided to go with the 5-speed ECU instead of the resistor hack that I normally use. I didn't know this ahead of time (or I would have charged more!), but in the '01 the automatic ECU uses the newer style 4-plug setup and the manual uses the older style 3-plug setup. Weird huh? I had to repin EVERY SINGLE WIRE that goes to the ECU into the new plugs:
Then I went about installing the master cylinder. This install is a breeze in the Toyota Celicas, but in the Corolla it's EXTREMELY hard. There's just a tiny bit of room to get in there with a 90-degree drill adapter.
Then I installed the clutch pedal.
Dropping the tranny out:
Fidanza flywheel...
Performance pedals...
TRD Short Shifter...
Corolla S Steering wheel and Airbag...
Stay tuned, there's more on the way!
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 12-07-2006, 09:34 PM   #2 (permalink)
4AFESPEED
TheOtherCarolla's Avatar
View TheOtherCarolla's Photo Gallery
looks like alot of work. Should be alot more fun when its done though
93' Prizm - Friend wrecked it R.I.P. 10-19-07
89' 240sx - Now daily driver, rb20 swap
FMIC, 11psi, 3in exhaust..
TheOtherCarolla is offline   Reply With Quote
Old 12-08-2006, 12:41 PM   #3 (permalink)
The Mad Scientist
Yeah no doubt, especially with the new exhaust and cold air intake and whatnot.
-Doc
Old 12-09-2006, 03:20 PM   #4 (permalink)
The Mad Scientist
Flywheel bolted up for real
Calipers being painted...
Installing the tranny...
Calipers painted red, backing plates and rotor centers painted black (the black on the braking surface will be cleaned off after using the brakes the first few times).
Dr Tweak Custom CAI (waiting on AEM Dryflow Filter and Air Bypass Filter)
Battery relocation in progress...
Old 12-09-2006, 04:36 PM   #5 (permalink)
View toyotaman90's Photo Gallery
Thumbs up
thats the kind of steering wheel i wanna get for my 95 corolla. where did you get it and how much did it cost
toyotaman90 is offline   Reply With Quote
Old 12-09-2006, 04:39 PM   #6 (permalink)
The Mad Scientist
I can get one for you including the airbag for $600. It will fit right onto the '95. Do you have cruise control?
-Doc
Old 12-09-2006, 04:42 PM   #7 (permalink)
yeah i got cruise control
Old 12-09-2006, 04:48 PM   #8 (permalink)
The Mad Scientist
Okay, yeah I can get you one, just let me know: drtweak@phoenixtuning.com
-Doc
Old 12-10-2006, 04:56 PM   #9 (permalink)
View LabtecDaN's Photo Gallery
how much would a auto to manual cost? i was thinking of doing that ..but then i didnt know if i should just get a another one with a manual tranny instead..
LabtecDaN is offline   Reply With Quote
Old 12-10-2006, 07:21 PM   #10 (permalink)
The Mad Scientist
Yeah it really does depend on how attached you are to your car and what you already have into it. Typically including all parts and labor you're looking at about $1950 using stock parts. This customer decided to go with a Fidanza flywheel, TRD short shifter, high performance clutch kit, etc, so it was more.
-Doc
Old 12-11-2006, 04:27 PM   #11 (permalink)
The Mad Scientist
Grounding kit installed... Only this missing here is the Air Bypass Filter...
Old 01-03-2007, 12:22 AM   #12 (permalink)
B!TCH IM DA BO$$
View alex06rolla's Photo Gallery
i crashed my corolla 06 and the insurance company gave me 2k to reinstall the airbag, i couldve just copped a new steering wheel the same as that and it only wouldve cost me 600??!!
alex06rolla is offline   Reply With Quote
Old 01-03-2007, 12:51 AM   #13 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
pretty much
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-12-2007, 09:09 AM   #14 (permalink)
xrsbou's Avatar
View xrsbou's Photo Gallery
just wondering what that grounding kit does
xrsbou is offline   Reply With Quote
Old 01-12-2007, 02:21 PM   #15 (permalink)
The Mad Scientist
With the coil-on-plug ignition, you can make a couple more hp by a better grounding setup.
-Doc
