In a 95, remove the 4 tips from the HVAC controls (they just pull off),
then gently pry around the plastic plate covering the radio/HVAC using a flat-head screwdriver.
After the plate pops off, you will need to unplug the wires for the Hazards, Defroster and Clock. The AC button just comes off on its own.
After that, there are 4 screws around the radio. Your CD player will screw right into the plate that is attached to the stock radio, and a wiring harness will allow that CD player to plug into the cars wires.
After that, its a simple matter of putting everything back together.
Also, any standard aftermarket CD player will fit fine.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
