Front wheel studs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2006, 07:47 PM   #1 (permalink)
View 93ToyCorolla's Photo Gallery
USA Front wheel studs
Today I replaced to front wheel studs. I did not remove the hub. I simple tapped the old ones out and placed the new ones in. I used a tighned a lug nut to pull them into place. My main question is I was not able to get them in all the way. Is there a better way to do this without removing the hub. What is the procedure to remove the hub? Thank You!
93ToyCorolla is offline   Reply With Quote
Old 12-09-2006, 07:59 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
to remove the hub you have to press apart the front wheel bearings from the spindle, this is done off the car.
use washers as spacers and a more powerful impact gun.
why are you replacing them?
Old 12-09-2006, 08:55 PM   #3 (permalink)
View tashirosgt's Photo Gallery
Auto parts stores have a heavy duty thing that resembles a socket which threads on the studs to pull them in place. But I'm surprised the lug nut didn't work. Are you dealing with a lot of rust?
tashirosgt is offline   Reply With Quote
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
front right wheel suspension rattle chesstompowell Camry & Solara Lounge 60 01-25-2007 05:52 PM
Why does my manual say my '06 is front wheel drive? HotRod53 2nd Generation (2005+) 1 11-17-2006 08:14 PM
wheel studs 1bad2WD 89-95 Toyota Pickup/Hilux 4 04-21-2006 10:07 AM
extended wheel studs abovethelaw Camry & Solara Lounge 26 09-09-2005 09:03 PM
