Cooling fan/electrical issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2006, 02:12 PM   #1 (permalink)
View Kanding's Photo Gallery
Hi guys,
My cooling fan is always on in my 93 Prizm. I checked the ECT switch on the thermostat as well as the cooling fan relays, all are ok. The only other problem that I can see that would cause this is a broken/loose connection in the wiring somewhere. Any ideas before I start testing the cooling system wiring for continuity (not looking forward to this)?
Kanding is offline   Reply With Quote
Old 12-10-2006, 03:28 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
faulty temp sensor to coolant maybe?
those damned sensors are expensive. I replaced 2 one day and paid about $50.00 at autozone.
Anyone else have a guess?
unless your engine is overheating..... and the sensors read the correct temp..
retiredat44 is offline   Reply With Quote
Old 12-10-2006, 04:58 PM   #3 (permalink)
Thanks for your thoughts. Since the ECT switch is controlled by the thermostat, and it works correctly, I think the thermo is ok, or at least, not the problem. If I unplug the fan and let the car sit, it heats up as it should and the initial high (cold) idle lowers, seemingly correctly.
Old 12-11-2006, 11:44 PM   #4 (permalink)
niko3257's Avatar
View niko3257's Photo Gallery
not to good with this stuff but would a A/C switch do it?
doesn't the fan run when the switch is on?
if it does could the switch be bad?
not sure but you could check it.
07 CAMRY CE
02 RC51/SP2
niko3257 is offline   Reply With Quote
Old 12-12-2006, 03:38 AM   #5 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
The switch on the thermostat housing should have different ohm readings for different temps. You would have to check specs in repair manual and use meter to check values. If that checks out I would strongly suspect the relay.
90 GP is offline   Reply With Quote
Had an issue with a dealer, need advice. Esco Hardcore Tech and Competition 15 09-09-2007 09:54 PM
1994 Camry stalling issue y2k2s2k 3rd & 4th Generation (1992–1996 & 1997–2001) 6 11-14-2006 02:27 AM
Air in Cooling System dlf60 Supra Forum 5 07-18-2006 10:53 AM
Pressurized cooling system - when COLD! nielsorj Archived Corolla threads 7 11-28-2005 03:31 AM
AE92 GTS cooling system.. WTF!! REN69 Archived Corolla threads 15 12-02-2002 07:13 AM
