Front Wheel Flutter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2006, 06:24 PM   #1 (permalink)
View gerryk's Photo Gallery
Front Wheel Flutter
Last week I slid my '06 Corolla on ice and broadsided the right front wheel on a curb. I notice that on highway driving there's a slight fluttering sound seeming to come from that wheel area. Quiet, but there. What might be wrong?
gerryk is offline   Reply With Quote
Old 12-10-2006, 06:56 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
jack it up and spin the wheel to listen to it, and also yank on it back and forth, jar it hard to see if anything is loose or bent.
at least that will give you some peace of mind...
retiredat44 is offline   Reply With Quote
Old 12-10-2006, 09:15 PM   #3 (permalink)
front wheel flutter
Thanks! I'll try it while the weather's mild.
Old 12-10-2006, 09:21 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I would check asap. If the wheel and brake rotor moves around seperate from everything else than well the wheel bearing is shot. If it moves around with everything else but has play check your tie rod ends.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 12-10-2006, 10:35 PM   #5 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Most probably you bent your rim and its throwing your tire off balance...If you check all the things others have said here and everything is OK then take that wheel in to check its balance...Same thing happened to a friend of mine...He tried to straighten the rim out but wound up buying another rim...You could also have damaged the sidewall of the tire...Good Luck
~Radd
Raddman is offline   Reply With Quote
Old 12-11-2006, 08:36 AM   #6 (permalink)
Sounds good. Thanks!
Old 12-11-2006, 12:32 PM   #7 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
may have hurt the lower balljoint.
Old 12-11-2006, 06:03 PM   #8 (permalink)
Mechanic looked at it today...didn't find anything wrong. He balanced it, and that may help.
Thanks!
Old 12-11-2006, 08:55 PM   #9 (permalink)
Question
so he spun the wheel and checked out all the parts that could be rubbing?
Old 12-17-2006, 03:59 PM   #10 (permalink)
Yes.
loud clicking/popping/crunching sound coming from right front wheel mi_carro 1st & 2nd Generation (1983–1986 & 1987-1991) 7 12-20-2006 08:29 PM
Driver's Side Front Wheel Brutus07 5th & 6th Generation (2002-2006 & 2007-2011) 11 11-10-2006 11:42 AM
Front wheel well trimming jadamjr 2nd Generation (2005+) 50 09-15-2006 11:34 AM
What's the best way to R&R front wheel bearing races(sp)? slbks5 89-95 Toyota Pickup/Hilux 0 10-21-2005 12:16 AM
