clutch/flywheel....gas tank? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2003, 08:38 AM   #1 (permalink)
View top-speed's Photo Gallery
Hey guys
I need some info
First
Wich clutch?
It;s a stock 1985 GTS, might get some bolts ons and cams, on mild rebuilt 4age
It;s gonna get driven hard
Is the stock clutch enough? If not wich one?
Second, flywheel
Wihc one? While i am in there ia m gonna get a light wieght flywheel
Who makes one and what weight is good?
Third
Gas tank, where can i get a reconditioned one or new one?
Thanks guys
www.top-speed.ca
top-speed is offline   Reply With Quote
Old 05-28-2003, 12:52 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Sounds like you have a lot of questions. Maybe try narrowing them down with a search here and also over at http://www.club4ag.com/.
I'm sure some one here can tell you what they're running as well... good luck
Chris Corolla S is offline   Reply With Quote
Old 05-28-2003, 01:22 PM   #3 (permalink)
View Midnight GSI's Photo Gallery
Hello
Hello
Clutch =ACT
Flywheel =TODA 3.7Kg.
Gas tank =Junk Yard
At least this is what I will be running here in a few months in my FWD(flywheel,clutch).
C-YA!!
Midnight Motorsports
86 Corolla GTS- race/drift-flipped & waiting to be fixed
88 Corolla GTS- race/work-broke & waiting for high comp block
88 FX-16 -daily 4 now
93 Toyota Truck - Tow/Play
03 Matrix - Family
www.Millenniumautosports.com
Midnight GSI is offline   Reply With Quote
Old 05-28-2003, 01:47 PM   #4 (permalink)
Thanks i ahve read alot of stuff on that site.
cool i will check those out
The closest gas tank is in otowa i think
Plus with 20 years o crap i would rather have a new one or reconditioned one.
www.top-speed.ca
Old 05-28-2003, 02:00 PM   #5 (permalink)
DerekDorifto's Avatar
View DerekDorifto's Photo Gallery
Is this Rob?
I'm Vivek's friend and saw you at Shannonville last year, saw the post on ClubSi about your new car too.
I have a 20v 4AGE 212mm flywheel with 2 used pressure plates and 2 used clutch discs.
This setup is 100% bolt on to your AE86, it's 3 lbs lighter than the smaller 200mm 18lb flywheel currently in your car. It's not shaved either, these 212mm flywheels weigh 15lbs straight from the factory.
Email me if you want these.
AW11 / AE86 / AE100
DerekDorifto is offline   Reply With Quote
Old 05-28-2003, 02:05 PM   #6 (permalink)
not too big on used clutches, but how used are they?
And yup this is Rob
I registed under zc911 first but i can;t post under that account name
www.top-speed.ca
Old 05-28-2003, 02:10 PM   #7 (permalink)
Lots of meat left, the clutch came straight off my 20v. You can give me a call to come see it for yourself if you want, I have matching 2 clutches and 2 pressure plates and just want to clear some space up in my garage for the rest of the 20v swap.
I can get brand new (not rebuilt) aftermarket 20v clutches if you want also. Sprung hubs, not rubber ones.
AW11 / AE86 / AE100
Old 05-28-2003, 02:17 PM   #8 (permalink)
i'll send you an email in 5min
www.top-speed.ca
Old 05-28-2003, 07:16 PM   #9 (permalink)
Dis reg!
AEugene86's Avatar
View AEugene86's Photo Gallery
you can get your gas tank coated with polyurathane at Gas Tank Renu. 1414 martingrove. (416) 744-2744. they quoted me 180+tx and a 3yr warranty. I gotta leak too and I wanna go next weekend to get this done.
'87 Corolla GT-S HB
AEugene86 is offline   Reply With Quote
Old 05-28-2003, 07:47 PM   #10 (permalink)
Hello
I would look into fitment issues w/ the 212 mm flywheel.
I think you will need to shave the inside of you tranny an use a differnt starter. Atleast you have to when dealing w/ the fwd layout's that start out as 200mm units.
Not sure about this one go to www.club4ag.com for more info.
C=YA!!
03 Matrix - Family
Old 05-28-2003, 08:24 PM   #11 (permalink)
You're totally mistaken for AE86.
The starter ring gear diameter is the same as the 200mm AE86 flywheel with the same number of teeth. This means you can use the AE86 starter - simply count the teeth if you doubt me.
It's the actual face of the flywheel that's 212mm, the overall diameter and thickness of the flywheel are still the same as the 200mm flywheel.
AW11 / AE86 / AE100
Old 05-28-2003, 10:06 PM   #12 (permalink)
I am gonna just pick up a new tank from crappy tire, $205
If you want the part number le tme know i will post it tommorw i left it in the car
www.top-speed.ca
Old 05-28-2003, 11:50 PM   #13 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
they got them in stock? holy shit, that surprises me
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 05-29-2003, 07:58 AM   #14 (permalink)
no tin stock, it has to be ordered, but he siad 1-2 days
www.top-speed.ca
Old 05-29-2003, 08:38 AM   #15 (permalink)
My bad!!
That's what I get for putting my FWD tech in the RWD world.
I know in the FWD it's the size of the starter sproket that has to match the flywheel to get good ingagement. (200vs212)
C-YA!!
03 Matrix - Family
