2003 Corolla Serpintine Belt Change Question??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2006, 08:27 AM   #1 (permalink)
View Dave-99-Z-71's Photo Gallery
Canada 2003 Corolla Serpintine Belt Change Question???
I can not figure out how to release the tensioner so I can change my serpintine belt. I found this photo on the forum so I was wondering once you loosen the bolt below the wrench, Do you really have to put a snipe on the wrench to force it or am I missing a step????
Dave
Dave-99-Z-71 is offline   Reply With Quote
Old 12-18-2006, 07:59 AM   #2 (permalink)
Someone must have changed a belt on a 2003 corolla???
Old 12-18-2006, 10:21 AM   #3 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
Originally Posted by Dave-99-Z-71
I'm thinking about changing mine also and was wondering the same thing ....I was just going to loosen the alternator up and do it that way and its right on top easy to get at....
Maybe rice knows he's an expert on everything
~Radd
Raddman is offline   Reply With Quote
Old 12-18-2006, 11:35 AM   #4 (permalink)
View White05's Photo Gallery
Putting the wrench on that bolt does not loosen the bolt but rather moves the tensioner so it gives you slack on the belt. While you have slack pull the belt off the pullies.
Hope this helps.
White05 is offline   Reply With Quote
Old 12-19-2006, 01:14 PM   #5 (permalink)
From the photo I know the wrench in the current position moves the tensior in order to gain slack to remove the belt. My question is that once I loosened the bolt just below the wrench, I was not able to make the tensioner release. I did not want to snipe it with a pipe because I did not know if I missed another bolt or step in order to release the tensioner? But maybe I am not putting enough torque on the wrench and should snipe it. Just don't want to break anything.
Dave
Old 12-19-2006, 02:50 PM   #6 (permalink)
Hmmmm,
You shouldn't have to loosen that bolt at all. As the belt starts to wear and loosen the tensioner should move freely to pick up the slack (so it won't slip as time wears on). You could try a longer wrench or pipe (like you said) to get more leverage. On the other cars I've owned instead of a bolt it was usually a 1/2" socket so you could use a breaker bar.
Old 12-19-2006, 02:54 PM   #7 (permalink)
View tank1080's Photo Gallery
theres no need to loosen that bolt under the wrench. it should pivot on that bolt. the only way you should loosen it is if you cannot move the adjuster
tank1080 is offline   Reply With Quote
Old 12-19-2006, 06:47 PM   #8 (permalink)
View joeking's Photo Gallery
You dont loosen anything. You put the wrench on the nut underneath the one you have the wrench on and it takes lots of strength to tension it out so it is loose enough to get the belt off. When you let go of the wrench it will spring back. Use a huge breaker bar with a socket and it also works better with two people. One to hold the wrench and the other to install the belt. I have never replaced one on a Corolla but have on several other cars. The trick is use a huge breaker bar so the tensioner is easy to release. Hope this helps.
joeking is offline   Reply With Quote
Old 12-20-2006, 08:01 AM   #9 (permalink)
Thanks for all your comments and help! I will use a large breaker bar and give it a lot more muscle. I just wanted to be sure because I have bad luck breaking things!
Dave
Old 12-20-2006, 08:04 AM   #10 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
Dave
good luck, you wont break anything this time
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
2003 Corolla Problem (Belt probably?) Jun118 Archived Corolla threads 4 07-03-2005 11:56 PM
questions about 2003 corolla S sick-boi Archived Corolla threads 9 04-04-2005 06:27 PM
Timing Belt Issues on 2005 Corolla XRS otamywy Archived Corolla threads 8 03-13-2005 08:19 AM
98 Corolla Belt Tensioner kevinp Archived Corolla threads 1 05-19-2004 04:52 AM
