92 Corolla Problem
Well, initially, I was going to post because the engine light came on a few days ago, and after checking most of the obvious things, and some not so obvious, I decided to reset the light on my own. This brings us to where I am now.....Well I took out the 15a fuse and disconnected the battery for a few minutes, reconnected everything, started the car up, and it worked great. The engine light stayed off, so I turned the car off and locked it up, when inside cleaned up, and got ready to head out. Unlocked the door, and the thing wouldn't open. It's as if the door stayed lock, even though the nob popped up. Fortunately, I was able to reach the inside handle via the driver's side rear door. I tried several times to open the driver's door from the outside however, nothing seems to work. Also, I noticed that now when I roll the window down on the driver side, it goes halfway then grinds to a halt, as if it were hitting something. This door and window worked perfectly until about an hour ago now.
Any ideas???
