Exhaust piping design question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2006, 01:03 PM   #1 (permalink)
TN TE/AE/SW Afficionado
View Chucez's Photo Gallery
AE92 Exhaust piping design question
So I'm going to be welding together the piping for my AE92's exhaust in a couple of weeks and I'm trying to decide whether or not I should do the following:
1) Send the pipes to a machine shop and have them bend 2 of the main pipes to hit 3 angles.
2) Buy a bunch of pre-bent pipes and weld them together.
3)Use a series of flanges to hold together the various piping components.
4)Instead of using flanges for everything, use 2 sets of flanges and then weld everything else together.
Since this is my first time working with pipes by myself, I'm not quite sure how much the shops will charge for making the bends. I understand that the welds and flanges will create some turbulence in the exhaust flow, but I feel that using a series of flanges will make taking it off and putting it on a lot easier.
thanks for any input,
Gino
Chucez is offline   Reply With Quote
Old 12-14-2006, 10:53 PM   #2 (permalink)
Danno
View 89yotarollagts's Photo Gallery
why put flanges on ? Weld everything ! Get the bends made as you need them ! Or you have the bends right under your car now, take out the old exhaust figure out what your going to need & then go for it !
Goodluck
~Dan
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 12-14-2006, 11:50 PM   #3 (permalink)
ahh... yeah you know I do have this rare skill of making everything much harder on myself, than it should be.
Thanks,
Gino
Old 12-15-2006, 12:19 AM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
if you have alot of bends it might be easier to get a pipe made up, if your gonna buy some bends and piece a system together use mandrel u bends as they are round through the bend and you can section them to the right angle, Personally i wouldn't weld from the manifold back solid, add maybe one set of flanges by the converter.
advice
- the closer the fit in joints the easier it will be to weld
- you can get flanges at most muffler shop because I know there a little hard to find
- if you have problems getting the welds to seal, get some pipe that just fits over, cut short 1" sections then slip them back over the welds and weld around each edge
- reroute a bit if possible, the fewer bends the better...
- As you fit pipe dont fully weld it, just tack it makes life easier if you have to make changes
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 12-16-2006, 01:49 AM   #5 (permalink)
Danno
lol ^ yea sorry i did include that.. make sure you keep a flex pipe in the system, from the flex pipe back you should weld everything lol
Popping Exhaust Question. modifierLE Camry & Solara Lounge 9 09-07-2005 07:59 PM
prob w 98 camry exhaust ---question sca676 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-07-2005 07:30 AM
Exhaust piping ekim55121 Camry & Solara Lounge 13 02-13-2005 01:00 AM
exhaust piping.... war0827 Camry & Solara Lounge 15 06-15-2004 02:20 PM
Exhaust Piping 86CRESSIDA86 General Discussion 7 02-27-2002 12:16 AM
