How do you like the Focals? I am using the Focal 165KP set. I had the same concerns about weight, but ended up adding about 115 lbs total: 35 lbs. of sound barrier material on the floor and firewall, 26 lbs. of dynamat extreme in trunk and 4 doors, 14 lbs. for the amp, and 40 lbs. for the subwoofer. When I go on longer trips or want full use of the trunk space, the subwoofer is removed. Unfortunately, the Corolla is not a very quiet or fast car. All of this was for a simple setup with just front speakers, a single 270 watt amp, and one 10" subwoofer. With this vehicle I would rather loose the subwoofer all together than the extra soundproofing (most of the music I listen to does not have a lot of material below 70Hz).
Originally Posted by punter
I've sort of got a SQ setup I suppose.
I've got focal access components with a small e-audio 280ab amp powering them.
I've sealed off the doors, and experemented with different tweater placements, they're in the sails at the moment.
I pretty happy with how it sounds, and I'm probably going to leave it as is, don't want to do anything to weigh the car down too much.
