I cant solve corolla stalling when stepping on the gas? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2006, 12:30 AM   #16 (permalink)
View 94_Rolla_Guy's Photo Gallery
OK it doesn't have a AFM it has a MAP sensor, it is a little black sensor on the firewall it has a small black hose going to it from the intake manifold and 3 wires its, by the windsheild wiper motor, test that and see if thats your problem....
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 12-19-2006, 11:02 AM   #17 (permalink)
View scorpiox's Photo Gallery
i have tried a used MAP sensor.. Still no go.. But i do think it is somewhere in that area.. some suction or vacuum problem.. hmmm
scorpiox is offline   Reply With Quote
Old 12-19-2006, 11:08 AM   #18 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
put some soapy water on your vaccum lines and then check for bubbles. where there is bubbles there is leaks. Also you can go lines from menards for like 2 bucks and do all the vaccum lines just to be sure.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 12-19-2006, 11:43 AM   #19 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Take it to a shop to have it diagnosed. Then get the part and repair it yourself. Otherwise your just gonna keep throwing parts at it which will cost you more money in the long run...if it already hasnt.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 12-22-2006, 02:13 AM   #20 (permalink)
This is crazy.. we have changed practically everything in the car
Old 12-22-2006, 11:33 PM   #21 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
you still didn't say if you had tried what I suggested.
Old 12-23-2006, 08:46 AM   #22 (permalink)
All-Trac Guru
Originally Posted by REN69
It's a Corolla, it came with a 4AFE or 7AFE, not a S series.
Scorpiox, have you tried testing the injectors? what about the fuel filter and pump??
Old 12-23-2006, 10:15 AM   #23 (permalink)
View Beemik's Photo Gallery
it could the injectors or the fpr valve. if you are stepping on the gas and the cel comes on it could be because the af ratio is too lean meaning lack of fuel. i would imagine if it was a vacume leak the car would idle high. i would check the injectors or put the old ones in if that doesnt work i would try the fpr
Beemik is offline   Reply With Quote
Old 01-04-2007, 05:07 PM   #24 (permalink)
View thisxstyle's Photo Gallery
Check your oxygen sensor. It may be running to rich to quick due to a faulty o2 sensor. I'd try checking what's listed above and the o2 sensors.
Pull out the o2 sensor and hit with a butane torch for 3-5 seconds at a time to burn off all of the build up. Don't hold it constant though, that would be dumb.
thisxstyle is offline   Reply With Quote
Corolla 98..starts but as if someone has put his feet on gas pedal/with high speed ajashadi Archived Corolla threads 14 09-14-2006 06:36 PM
1997 Corolla Seca hatch - Toyota spec for 68960 YA 020 gas struts pressure? celicadog Archived Corolla threads 3 05-31-2006 09:47 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
89 corolla GTS needs 92 octane gas? probemartin Archived Corolla threads 26 11-02-2002 03:02 PM
1991 Corolla Stalling corollamax Archived Corolla threads 9 09-06-2002 11:19 PM
