Brake Pads and Rotors for an 05 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2006, 07:32 PM   #1 (permalink)
View White05's Photo Gallery
Hi Everyone, I need some newb help
I have 43,XXX miles on my 05 corolla and was wondering if I could just replace the pads but not the rotors on the front. I bought both the rotors and pads with the intention of changing both, but when I took the wheels off I noticed that I would have to remove the axle bolt as well. When I went back to NAPA to get a socket they could not tell me which one I would need - nor did they know which axle bolt I would need (I figured they were one time use only).
Any help would be appreciated.
Thanks
White05 is offline   Reply With Quote
Old 12-18-2006, 12:41 AM   #2 (permalink)
View NiceSR5's Photo Gallery
Check a repair manual to see if the axle nut needs to removed for the rotor to be changed. I don't think so. I did a brake job on a 94 or 95 rolla once and all I did was remove the calipers & brackets and then the rotors were stuck on with rust. With some WD40 and a slight banging of a hammer they came off. I had them machine turned for 8 bucks at Pep Boys. There are some members here that know of some web sites that have info on the repair manual.
NiceSR5 is offline   Reply With Quote
Old 12-18-2006, 01:00 AM   #3 (permalink)
View toyomoho's Photo Gallery
Once you get the caliber off, the rotor should come off.
Old 12-18-2006, 09:31 AM   #4 (permalink)
That did the trick thanks for the help NiceSR5,
Old 12-18-2006, 10:59 AM   #5 (permalink)
Cool, wait to you get to the rear drums. That's another adventure.
Old 12-18-2006, 11:06 AM   #6 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
sure is
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 12-18-2006, 12:02 PM   #7 (permalink)
View prophase's Photo Gallery
We all know replace drum brakes sucks balls. So many little things to do. I wonder why cars even use drum brakes anymore.
05 Corolla LE
07 Subaru 2.5i wagon - modded
prophase is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 02:32 AM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 08:48 AM
Gen4 brake rotors and pads replacement Luc Hardcore Tech and Competition 4 01-24-2005 08:04 PM
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 12:46 PM
