4afe running like shit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2006, 09:56 PM   #1 (permalink)
big_fella6699's Avatar
View big_fella6699's Photo Gallery
Exclamation 4afe running like shit
hey guys, i was wondering if u cold help me.
my alltrak corolla has started playing up. at low revs one of the cylinders stops working every now and then and will only start 2 run normally again when the engine reaches about 2500-3000 rpm. it is missfiring a bit atm, but my main worry is that in low revs one of the cylinders keeps dropping out. any help would be much appreciated. thanks
1988 ae95 corolla - extractors, pod filter - SOLD.
1986 mazda 929 turbo - 2.5" catback, boost cont, bov - DRIVING (for sale).
19** ke70 corolla, chopped springs all round, welded diff, more 2 come... - DRIVING.
big_fella6699 is offline   Reply With Quote
Old 12-19-2006, 10:26 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
alright, check the wires, plugs, cap, rotor, coil. go from the plugs backwards till you find the problem.
Old 12-19-2006, 10:41 PM   #3 (permalink)
thanks, its not the plugs coz i replaced them just the other day, but i know its only cylinder 3 thats cutting out... would that rule out the cap, rotor and coil?
Old 12-19-2006, 11:24 PM   #4 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
how do you know its only cylinder 3, and because you replaced the plugs the other day it very well could be the problem. why is that cylinder cutting out. check the dizzy cap. connector for that cylinders spark plug wire could be corrodered very bad. also did the plug in cylinder 3 have any oil on it? if there was oil try replacing the valve cover gasket and the o rings around the spark plug holes.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 12-20-2006, 06:56 PM   #5 (permalink)
View NiceSR5's Photo Gallery
Cap, rotor and wires......It happened to me at 110K miles, exactly how you explained. Here in CT, aftermarket cost only 13 dollars less than the original Toyota piece. If you can go with original do it..... trust me it's worth it. I changed out those so called "liftetime wires" 3 times until I was fed up and just purchased the originals. There is a set I read in a magazine that is basically racing wires but costs more. Try eBay, NAPA or Parts America.
NiceSR5 is offline   Reply With Quote
Old 12-20-2006, 07:40 PM   #6 (permalink)
Infinitrium's Avatar
View Infinitrium's Photo Gallery
Don't forget rockauto.com
Infinitrium is offline   Reply With Quote
Old 12-21-2006, 11:44 AM   #7 (permalink)
All-Trac Guru
so did you fix it yet or what? let us know
Old 12-21-2006, 07:22 PM   #8 (permalink)
hey guys, sorry i didnt reply sooner, i havent really had a chance 2 jump on here. umm i found that the more i drove the car, the less it stuffed up... my guess was a partially blocked injector so we chucked some wynns injector cleaner in and its cleared up heaps... thanks for ur help though... much appreciated.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
4agze Wiring Harness on a 4AFE?. toyloco Archived Corolla threads 3 07-25-2006 10:09 AM
4afe --> 4agze alternator pinouts? HELP plz mhiscott Archived Corolla threads 0 05-07-2006 05:39 PM
Partial NASCAR Truck Race Results Sportivo Concepts General Discussion 4 02-14-2004 11:22 PM
my engine is BOGGING.....running like a bag of shit streetXtreme MR2 Forum 3 11-26-2003 04:42 PM
