Power-Shifting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2006, 10:54 PM   #1 (permalink)
View goooopher's Photo Gallery
Power-Shifting
Hey i was talking to a friend of mine today and the topic of power-shifting came up when he told me he blew out his clutch on his STI. I asked how he got home bc he did it on a major highway...he said he powershifted all the way home...i about more details and i decided to go and give it a try in the corolla lol It went pretty well considering i dont have a tach...drove arounf for like 15min using the clutch to stop and to downshift, but i got the hang of it going from 2nd-3rd, 3rd-4th, and 4th-5th...1st to 2nd was tough but aside from that it was fine. Didnt grind the gears except for the first shot at it from 3rd-4th, but anyway i couldnt downshift...upshifting was not an issue, but i was wondering if there were any tips for how to downshift...
goooopher is offline   Reply With Quote
Old 12-19-2006, 11:21 PM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
when you pull it out of gear tap the gas and let the shifter fall into place as the rpm's fall to the right level. Its all about rev matching. but shifting like that is hell on the transmission. your wearing it down for no reason.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 12-19-2006, 11:22 PM   #3 (permalink)
View toyomoho's Photo Gallery
You need to time when let off the gas and shift. The torque needs to be removed from the trans gears to allow them to disengage/engage freely. Might limit power shifting, it is hard on the syncro rings and will wear then out prematurely.
Old 12-20-2006, 03:02 AM   #4 (permalink)
View DoubleEdgedWomb's Photo Gallery
It's bad for the transmission. Why do it if you have a working clutch?
DoubleEdgedWomb is offline   Reply With Quote
Old 12-20-2006, 05:04 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I did it on my car just to learn it just incase it happens
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 12-20-2006, 07:20 AM   #6 (permalink)
exactly...im in need of a new clutch soon as it is and i just want to be able to do it if the clutch does decide to go on me...
Old 12-20-2006, 07:45 AM   #7 (permalink)
All-Trac Guru
if i knew my clutch was on the way out, i would replace it before it did go out. just my .02
Old 12-20-2006, 08:29 AM   #8 (permalink)
View dgoodhue's Photo Gallery
I described downshifting in the 2nd to last post in this thread.
http://www.toyotanation.com/forum/t166083.html
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 12-20-2006, 08:37 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I wouldnt even bother with it, unless it was a worst case scenario as in being stuck in the middle of nowhere, without a working clutch. Why fuck up the tranny more than just the clutch. A clutch doesnt cost much, a whole tranny does, in comparison.
Doing stupid things to your car without reason =
Old 12-20-2006, 12:50 PM   #10 (permalink)
View t_cel_t's Photo Gallery
um yeah shifting without using the clutch is NOT powershifting, powershifting is keeping your foot planted on the gas and slamming down the clutch and pulling the shifter into the next gear and slipping your foot off the clutch. whole process takes about .25sec. what you are describing is shifting without clutching, not all that bad if you know how to do it. hell when i drive any type of big truck/semi i dont even use the clutch for anything other than first starting out.
t_cel_t is offline   Reply With Quote
Old 12-20-2006, 01:26 PM   #11 (permalink)
I have actually heard people do that process w/o using the clutch. WOT clutchless shifts.
Dave
02 Highlander
Old 12-20-2006, 03:26 PM   #12 (permalink)
Semis have straight-cut gears though, so they can handle being shifted without using the clutch.
Old 12-20-2006, 04:38 PM   #13 (permalink)
Resident asshole
Flashmn's Avatar
^ditto, your corolla doesnt. Trucks also lack synchros for most part, your corolla doesnt. You're hurting your gearbox alot. Dumb.
Old 12-20-2006, 04:49 PM   #14 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Bingo! if you want to destroy your transmission quickly and efficiently in order to accelerate faster, you found your answer.
Powershifting is the most awesome way to blow your tranny.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 12-20-2006, 05:21 PM   #15 (permalink)
View Electric Pi's Photo Gallery
Perhaps someone with more expertise in transmissions can shed some more light on this, but my understanding is that the important difference is syncro vs. dogbox not straight cut vs. helical cut gears. As I understand it there is no significant difference in the strength of helical gears vs. straight cut gears, and the failure point is more likely to be the dogs anyway. In a dog box they are designed to take more abuse because there are no syncros to ease engagement. It is my understanding that straight cut gears are commonly used on dog boxes because they are much cheaper to make, especially in small volumes. This article seems to support my understanding: http://forums.nasioc.com/forums/showthread.php?t=665334
P.S. t_cel_t is right. we are talking about presure shifting not power shifting.
Rally = Real cars, on real roads, going real fast.
http://www.youtube.com/ElectricPi
Originally Posted by rice
how do you guys tell if a car is AWD??
Electric Pi is offline   Reply With Quote
Lexus History BLUEMEANIE General Lexus Discussion 8 11-25-2011 12:53 PM
power steering belt removal and crank pulley Q's CrawlingEye Camry & Solara Lounge 1 06-28-2005 04:51 PM
decrease in power! HELP! kasimmmmm General Discussion 17 04-21-2004 09:20 PM
