Before you even go that far. When you say the car doesnt start; does that mean the starter wont spin? The engine doesnt try to crank? A few specifics might be of some help.
Divers right more info needed
Always remember to disconnect the battery before doing a replacement...That said there is a few wires that go onto the small post on the starter...Have you put them all on and correctly and tightened them up?
If your can doesn't crank at all look for a loose wire going to the small post on the starter...Similar thing happened to my friend and we found one small wire loose just laying in the connector not making contact.,..
Guess the worse thing is if you had a spark(from the battery not being disconnected) and it burnt out one of your sensors...Or your battery just might be dead.....
Good Luck...Let us know the outcome...
~Radd
