Originally Posted by daniel2002p
what year is the car? could be a messed up MAF
D
since its a 2003 it is a messed up maf. check the MAF and make sure you too didnt remove it
If your using an oiled filter you could of put to much oil on the filter and the oil got sucked up and covered the MAF making it impossible for the MAF to give an accurate reading of air passing by throwing the car into safe mode. The car is in a mode somewhat like safe mode. It wont go past 3000rpms to reduce the chance of hurting its self!
