2002 Rolla 1.8 trunk light fuse?.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2006, 06:04 PM   #1 (permalink)
View Emc-Icon's Photo Gallery
ok, so the trunk light wont work, and the bulb itself is fine, so it must be a fuse.. the problem is that the fuse itself must be blown.. can anyone tell me the approximate (precise = better) location of this fuse?...
TYVM
Emc-Icon is offline   Reply With Quote
Old 12-23-2006, 11:08 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
You should be able to find that in the owners manual.
diver9000 is offline   Reply With Quote
Old 12-24-2006, 12:22 PM   #3 (permalink)
not to be an ass..
but.. if i HAD the owners manual.. i wouldnt be asking here..
much help you guys are...
Old 12-24-2006, 12:31 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
No such thing as a trunk light "fuse" so it's probably a wire that's grounded or bad. The trunk light is probably attached to another fuse that runs more than just the trunk light, probably the tail lights or interior lights, so if you've noticed something else that doesn't work then it would be easier to find out.
Not to be an ass either but that's why they sell fuse testers, you can buy one and test ALL your fuses.
Old 12-24-2006, 12:33 PM   #5 (permalink)
thats definitely a possibility.. im gonna have to check around on that.. because the car im talking about had the wiring harness replaced.. so its possible that they didnt do EVERYthing perfectly.. if that.. then where is the trunk light supposed to be grounded?...
Old 12-24-2006, 05:08 PM   #6 (permalink)
View cheesep's Photo Gallery
The fuse for the trunk light is the same one as the dome light. It's the 15A DOME fuse located in the fuse panel under the hood on top of the driver's side fenderwell. If the fuse is blown, your dome light won't work either.
The switch for the trunk light is located down in the little pit immediately to the left of the trunk latch. One end is connected to the bulb socket and the other end is grounded. It looks like a black top spring-loaded button.
There is 12v power at the trunk light bulb all the time. When you open the trunk the spring-loaded switch closes and grounds the circuit so the light goes on.
Good luck and Merry Christmas!
cheesep is offline   Reply With Quote
Old 12-27-2006, 06:28 PM   #7 (permalink)
View bandag's Photo Gallery
And go to the dealer and get an owners manual. if you are going to keep the car for a while there will be other things that you will need to know that are in the manual. I can also give you a place that you can send for a used one.
bandag is offline   Reply With Quote
Old 12-28-2006, 12:02 PM   #8 (permalink)
At least get a Haynes Manual . . .
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
2002 sentra gxe trunk lid nobrainer Off Topic 7 12-08-2004 12:32 PM
Trunk Light Bulb Number? Stealth Camry & Solara Lounge 5 04-27-2003 07:05 PM
