just acuired a blacktop FC
i just won a FC on ebay from (JAPAN DIRECT AUTO PARTS INC are they any good?) its a ae111 6-speed with super strut. *note i've searched and i started this forum to verify the info*
heres what i found.
-the 6-speed will will work on the ae92. the axles will also bolt in no problem.
-any flywheel (fidanza) will work with the 20v you just need to get the right clutch for the flywheel and the right pressure plate for the tranny.
questions i have.
-??how do i run open throttles on the blacktop what do i need to do??(no ones ever really fully answered this question)
-??will the gauge cluster from the ae111 work or should i stick to the oem one??
-??should i even bother using the dual piston calipers
this car that im building up is tuned as a street/track car in mind. while i am adding parts i am also removeing as much of the cas weight as possible. why i chose this engine is 1.-ITB 2. staying NA 3.160-170hp was my goal only don't need much more to have fun at the track.
also how has anyone lifted or delt with a half cut of a car?
FS-crower stage 2 cams and new obx 4-2-1 header.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
