AC system shot? Any advice?
Looking for a 2nd opinion -- any advice is appreciated!
Background: My fiancee drives an automatic '02 Corola LE with ~40k miles on it. This past Sunday, I started the car, and after about ~1 second it started almost stalling -- sending the RPMs from normal (1500) down to almost 0, bouncing back up before stalling again. I tried re-starting and giving it more gas, and it started up and ran just fine. Two days later, it was reliably doing the same thing -- almost stalling at startup without extra gas.
I took it to a shop, and after running diagnostics they said the AC compressor had siezed (?) and needed to be replaced. In addition, they say the compressor created metal shavings that are now in the system and can't be flushed. So, I also have to replace the AC condensor, receiver dryer and the expansion valve -- grand total for parts/labor = $1535.89!!!
I know fixing AC systems can be expensive, but this was way more than I anticipated. Does this sound reasonable? I've heard that Corola's have a lousy history of AC systems...anyone else have this kind of problem? Any advice?
Thanks in advance!!
Brian
ps -- the guys at the shop took the AC offline, and the start-up problem appears to be fixed. So I have a few months until we need the AC...
