7A-FE headder, what injectors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2006, 06:50 PM   #1 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Hello all.
I usually hang out on the Tercel page and now will be hanging out around here also, since I have just become the proud owner of a bright red '92 Corolla sedan, (AE94) with massive radiator and exhaust leaks (and who knows what else wrong), that I won on E-bay for a pretty good price (I think).
I told the wife that the car is supposed to be for my son who is about to start driving(but I didn't tell her, only if it doesn't autocross better than my '89 Tercel with Paseo engine and suspension). If it does, then it is mine and he gets the Tercel.
I am thinking of putting in a 7A-FE, available at my local U-pull junk yard for the grand price of $175.00. I have been searching and reading through the posts and am pleased to see that I can use the 4A-FE wiring and ECU with the 7A engine.
The big question I have is, if I use an after-market intake and a headder with a 2" pipe all the way back, do I need to up-grade my injectors, and if so what injectors should I look for. (I am talking salvage yard specials, Celica, Camry, other)
I am also toying with the idea of later (when funds allow) getting a 4A-GE 20V, but am curious about how difficult it might be to get parts for these engines since I don't think these were sold in the US. Does anybody import parts for these regularly?
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 12-27-2006, 06:59 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
No an intake nor a header would cause any reason to swap injectors, there isnt gonna be such a drastic change in air consumption.
Old 12-27-2006, 11:40 PM   #3 (permalink)
View goooopher's Photo Gallery
The man is right. The only real point to getting new injectors if if A) You go super or turbo, or B) If your injectors are gunked to the point that you cant clean them...I personally noticed a little worse fuel economy when i put my intake, headers, and exhaust in...but that is simply because when these cars come stock their built to be fuel efficiant and when you do i/h/e you change that fuel ratio from its setting by letting more air to come in...But no need for new injectors..will a 4a-ge fit in a paseo or tercel? Never heard of such a swap being done...?
goooopher is offline   Reply With Quote
Old 12-28-2006, 12:21 AM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
umm it doesn't have to be forced induction to need larger injectors. A N/A motor can need them too but not for headers and intake.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 12-28-2006, 01:23 AM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
i have the ebay 7afe header and the a/f's i see on my wideband are all within normal.
if you're going to swap a motor then please for the love of god get one with a complete harness and correct PCM. obd1 motor with an obd2 pcm or harness is a nightmare or any mismatch of the 3 is bad bad bad. the 4afe pcm CAN run the 7afe, but i wouldnt do it. it has different fuel and timing maps, the fuel maps arent that much different but i believe that the timeing curves are different between the 2 engines, since the 4afe and 7afe have much different torque curves.
Bitter is online now   Reply With Quote
Old 12-28-2006, 08:40 PM   #6 (permalink)
Donald's Avatar
Thanks for the responses guys. Much appreciated.
To Goooopher - The 4A-GE is planed for the Corolla, but there are several Tercels running around with them, though it requires a few inches of frame cutting to get clearance for the tranny or the pulleys, and custom mounts. Visit the Tercel page.
If I keep the Tercel for myself, I might just squeeze in a 20V.
Why I asked about the lnjectors is, I put the Paseo engine into my Tercel with a headder, 2" pipe and a cone filter to replace the original filter box. I found that It felt lean on accelleration and my plugs were white. I was just recently directed to a tercel site that listed various injectors, their resistance, "cc" output and what cars they can be found in, that fit the Paseo engine. I put in a set from a 4cyl Camry and have found my throttle response is a lot better, no more lean bog when I accellerate. I haven't had them in long enough to check the milage accurately but it seems to be about the same as before. The difference is from 185 cc/min to 200 cc/min.
Oh, the head gasket is shot on the Corolla. Water in the oil.
Time for an engine swap, I think.
7A - FE Oil Consumption 94 Rolla Guy Hardcore Tech and Competition 8 01-16-2008 09:41 AM
FS: smt-6 + 2x 550cc injectors Toysrme Car Parts for Sale 7 10-29-2006 05:37 PM
Bigger injectors/ Fuel pump in 4th gen 97camryman Camry & Solara Lounge 4 11-15-2004 05:48 PM
Fuel injectors for 3SFE change in Gen2 es250nut 1st & 2nd Generation (1983–1986 & 1987-1991) 4 09-07-2004 09:30 PM
Injectors luisitol Camry & Solara Lounge 9 09-30-2003 05:56 PM
