This is for our 1998 Corolla CE. From my research with the search engine in this forum, it states that the 19mm bolt from the tensioner pulley should be loosened in order to loosen and remove the old serpentine belt. However, in our Corolla it appears that this 19mm bolt is not a real bolt; rather, it's welded to look like a bolt attached to the tensioner pulley. So it confuses me on how I should go about as far as removing this 19mm bolt. Also, right next to this bolt is a 17mm hex nut on the tensioner pulley. I tried to unscrew the 17mm bolt but it won't budge, not even after penetrating it with some WD-40.
So I'm at a loss right now, and I need some serious help as I'm hesitant on bringing the car to the dealer and get raped on the charges for the belt work. What should I do at this point?
