HELP is '93 Corolla 1.6 interference engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2006, 11:00 AM   #1 (permalink)
View 93corolla5speed's Photo Gallery
Hello, new to the forum today...
I cannot find a straight answer to this question...is my 1993 Corolla with DOHC 16 valve EFI 1.6 an interference motor?
From what I have found, the SOHC 8-valve 1.6 in the previous generation was a NON-interference engine...and that when it was redesigned and put into the 1993-97 generation Corolla/Prizm, it became an interference engine. Other places online swear my engine is a non-interference engine, though.
So, I came here to get a straight answer...
I am 10K miles past the timing belt change interval already and am trying to figure out if it is worth changing the belt ($300+) on a 14 year old car with close to 200K on it. If it is a non-interference engine, I will just let it go and if it breaks, I get towed home and have it fixed. I am not sure if I want to take this chance with an interference engine.
Thanks in advance for your help.
93corolla5speed is offline   Reply With Quote
Old 12-30-2006, 12:48 PM   #2 (permalink)
View darcsyde's Photo Gallery
yes change it, it's non-interference as well
darcsyde is offline   Reply With Quote
Old 12-30-2006, 12:49 PM   #3 (permalink)
View cheesep's Photo Gallery
It's non-interference according to the Gates Belts Catalog.
cheesep is offline   Reply With Quote
Old 12-30-2006, 01:38 PM   #4 (permalink)
View goooopher's Photo Gallery
non-interference?
goooopher is offline   Reply With Quote
Old 12-30-2006, 01:46 PM   #5 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
Originally Posted by goooopher
non-interference?
the piston's and valve's wont get in a fight if the timing belt snaps
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 12-30-2006, 02:20 PM   #6 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
USA
That is a lousy way to treat your engine. If you change the belt yourself, it will only cost you about $12.00.
diver9000 is offline   Reply With Quote
Old 12-30-2006, 05:02 PM   #7 (permalink)
Thanks for letting me know about it being a non-interference engine...
The only reason I will let it go until it breaks is that there will be no harm. Perhaps it will never break. Fact is the car has 200K miles on it and I just discovered today that the CV joint boots are shredded. That's money I have to spend on this 14 year old car, but the timing belt is not.
I just don't want to spend the money on a car of this age unless I have to.
As for changing it myself, I was looking under the hood while changing the oil and it doesn't look like something I want to attempt. I have had bad experiences when attempting repairs on my own!
Old 12-30-2006, 05:30 PM   #8 (permalink)
View motu 56's Photo Gallery
Change the belt. A belt change cost the same as one car payment. It will break at the worst time. You will have a towing change, a possible rental, and a missed appointment.
motu 56 is offline   Reply With Quote
Old 12-31-2006, 03:58 PM   #9 (permalink)
How much does it cost to have a timing belt changed? (mainly interested in hours of labor as the part is cheap)
Old 12-31-2006, 08:25 PM   #10 (permalink)
250$
Old 01-01-2007, 11:32 AM   #11 (permalink)
View 94_Rolla_Guy's Photo Gallery
take care of it and it probably still has plenty life left! why go kill it by neglect? there still worth a bit too if there not trashed...
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 01-01-2007, 08:53 PM   #12 (permalink)
diver9000's Avatar
Preventive Maintenance is always beneficial. There are lots of ppl that know how to do timing belts. Have any friends or neighbors that know how? They probably wont charge you if you ask them to show you how instead of asking to do it for you. Its fairly simple if you follow the steps in the repair manual or watch someone else do it once. You will save a ton of money if you take some time and research it, and your car will probably last a long time if you change the way you think about it. Good Luck
Old 01-02-2007, 01:57 AM   #13 (permalink)
Originally Posted by motu 56
250$
seems a little low...i am getting mine done by a local trusted garage and they quoted me 400...include water pump since its right there and a boat load more to do if it goes after getting the belt done...so it is quite pointless not to do the h2o pump if its right there...
Old 01-02-2007, 12:11 PM   #14 (permalink)
It is what I paid in the past. I am in Texas so prices are lower then the rest of the country.
Old 01-03-2007, 11:39 AM   #15 (permalink)
blb
View blb's Photo Gallery
Why GUESS as to whether it needs to be changed or not? It takes all of ten minutes to loosen the valve cover, remove the top timing belt cover, rotate the engine and check the entire belt for cracks, frayed edges or other issues. It all depends on the quality of the belt and your driving conditions on whether it will last 60,000 miles or 260,00 miles.
blb is offline   Reply With Quote
1993-1995 toyot Corolla Engine swap thakid Archived Corolla threads 9 03-09-2009 12:32 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
my 93 corolla needs some umph td420 Archived Corolla threads 1 10-18-2004 11:39 AM
