Bad Toe-out Rear Whl (AE92) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2007, 01:15 PM   #1 (permalink)
View texasrolla's Photo Gallery
USA Bad Toe-out Rear Whl (AE92)
Howdy folks,
My ae92 has got alignment issue. The toe-out on the rear wheel is about 1.3 degrees, and the lower-back control arm (cam adjust-type) is already extended to the maximum setting. All the linkages looks straight, and so does the frame. What else could be the culprit?
The previous owner replaced the strut (because of an accident) and the knuckle (because of bad wheel bearing). The camber is slightly off, but I think that can be corrected with one of those camber kit (crash bolt). The only theory I have now is that the previous owner replaced the knuckle with the wrong one. Did the AE92 'rollas come with different knuckles?
Thanks.
texasrolla is offline   Reply With Quote
Old 01-04-2007, 04:03 PM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Did he replace all the struts or just one? You have a fwd or rwd corolla?
diver9000 is offline   Reply With Quote
Old 01-04-2007, 04:25 PM   #3 (permalink)
Gen6
Only the left-rear strut was replaced because that was where the damage occurred, and the left-rear wheel is the one with excessive toe-out. The previous owner told me he went to the junkyard and got the entire strut assembly plus the knuckle off of a similar Corolla.
My AE92 is FWD. I think all ae92 are FWD.
The end-all thread for AE92 drum to disk rear aaron7 Archived Corolla threads 9 05-06-2006 04:58 AM
AE92 rear wiper....? aaron7 Archived Corolla threads 14 04-05-2006 02:39 AM
AE92 Rear disc brake conversion and other ?s White89SR5 Archived Corolla threads 2 04-11-2005 11:36 AM
TRD Rear Sway Bars--the good and the bad Lumberg Camry & Solara Lounge 39 09-21-2004 07:18 AM
