Service Engine Soon light is on..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2007, 07:37 PM   #1 (permalink)
View joeking's Photo Gallery
I have an 03 Corolla with 215,000 miles and the check engine light came on when I was driving on the interstate. It came on before and I unhooked the battery and it was ok. However, every time I go on the interstate it comes on after about 40 to 150 interstate highway miles. I didnt do the diagnostic on it. Does anyone have an idea to repair it without having to spend the money on the diagnostic? Thanks in advance.
joeking is offline   Reply With Quote
Old 01-04-2007, 07:40 PM   #2 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $489401
View falnfenix's Photo Gallery
sure. pull the code - go to Autozone and rent a code reader...or go to Pep Boys/Salvo and have them pull it for you.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 01-04-2007, 08:08 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
i'll venture a guess that its EGR related, when you're not on the highway do you ever get above 45mph for more than 3 minutes?
Old 01-04-2007, 08:32 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
215,000miles in an 03? probably time for the light to pop up, cars don't run forever dude; but I'll bet it's probably emissions related due to the mileage.
Old 01-05-2007, 07:03 AM   #5 (permalink)
Thanks guys. I will have it checked out and let you know. Honestly the car should still go another 200,000. After all, it;s a Toyota.
Old 01-05-2007, 08:56 AM   #6 (permalink)
View jon_570's Photo Gallery
how do you get that many miles in a lil over 3 years?
jon_570 is offline   Reply With Quote
Old 01-05-2007, 09:04 AM   #7 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
I'm assuming he's in sales or commutes a lot to get to work. He did say after 40-150 highway miles
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-06-2007, 02:04 AM   #8 (permalink)
bonnie*'s Avatar
View bonnie*'s Photo Gallery
Follow the suggestions from community members:
1) falnfenix vbmenu_register("postmenu_1579355", true); : sure. pull the code - go to Autozone and rent a code reader...
KNOW DTC TROUBLE CODE
2) Bitter vbmenu_register("postmenu_1579394", true); : ... guess that its EGR related, when you're not on the highway do you ever get above 45mph for more than 3 minutes?
3) READ THE THREAD Do-It-yourself Check engine Light diagnosis. First follow the diagnosis step 5 : EGR – Exhaust Gas Recycle, carry-out self maintenance for EGR SYSTEM and reset the code. If it remains unsolved then follow other steps too!
http://www.toyotanation.com/forum/t171748.html
Provide your detailed feed-back, once it's resolved.
Tks
bonnie*
bonnie* is offline   Reply With Quote
Old 01-06-2007, 10:26 AM   #9 (permalink)
Ok here's the deal. The car was purchased from a local hospital and was used on the interstate 375 miles per day to deliver exrays. I put 7,000 miles on it myself. I had the check completed and it needs a cat coverter. The shop wanted 1,116.00 to replace the cat. I checked the net and found a new direct fit unit 87 inches long...pipes and all for $288.00 delivered to the door. I also found a weld in cat for only $59.95. I know if I bought the $288 deal I would be in great shape. Has anyone ever tired the weld-in catalytic converter? I believe I would be better off spending the $288 and not have to worry about it. Let me know what you think. The $59 sounds great however I do not know if it will be an installation problem. It looked a little hokey in the sales picture.
Old 01-06-2007, 10:31 AM   #10 (permalink)
All-Trac Guru
buy the direct fit cat, save you lots of time with welding. damn that car got those miles piled on real fast
Old 01-06-2007, 10:32 AM   #11 (permalink)
KDM is in
REN69's Avatar
Just get one welded in dude, if not get the direct bolt on one.. $1100 to replace a Cat, that's just ridiculous.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 01-06-2007, 10:36 AM   #12 (permalink)
All-Trac Guru
he can do the bolt on one in his driveway, i imagine he would have to pay someone to weld the 59.99 one in (P.S. you get what you pay for)
Old 01-06-2007, 05:08 PM   #13 (permalink)
I called the discount muffler shop in the area and the guy told me over the phone that he could install a converter (the weld in type) for $159.95 out the door. He said he didnt show one in stop but thought he could find one that would work. The muffler shop has a good reputation so I made an appointment for Thursday.
Old 01-06-2007, 05:49 PM   #14 (permalink)
Bitter's Avatar
is the weld in an OBD2 cat? i'd be wary for $60... if its not an OBD2 3 way converter you'll probably fail the next emissions check or pop another engine light, probably P04xx.
what was the original code, you never told us? sometimes a bad O2 sensor or other problems can lead to a false diagnosis of a bad converter, 200k isnt that many miles for a converter.
Old 01-07-2007, 08:42 AM   #15 (permalink)
The $33.67 diagnosis: computer scan data,inspect other components: P0420 Catalyst Efficiency. Sevices recommended: Replace catalytic converter assembly/Reflash PCM.
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
reset procedure Service Maintenance Reminder Light Suikelley 2nd Generation (2004-2010) 1 08-18-2007 11:24 AM
1995 corolla check engine light ltnflvr Archived Corolla threads 6 01-12-2007 11:23 AM
engine light - P1410, P0135 & P0155 csi98 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-11-2007 05:08 PM
1990 Camry Check Engine Light Kep Hardcore Tech and Competition 4 05-20-2006 01:15 PM
