03 Corolla Battery Question! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2007, 09:10 PM   #1 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA 03 Corolla Battery Question!
I just went to Autozone and had my battery tested on my 03 Corolla, it was going on 4 years so I had it checked out!
The person that tested my battery said that the "green eye" on the battery only should that one cell and even if it showed the normal green eye other cells might be bad!
My question is...
Is this true?
How many cell does my battery have?
Is there a set time 4-5-6 years that I should replace my battery?
Or should I just wait till it starts giving me problems, but if it dies I might be out in the boondocks somewhere!
Reason I had it checked was first thing in the morning when it was cold it cranked slow but always started, never did this in years past but no other type problems...
BTW Battery and alternator both checked out fine!
Any input or help on this subject would be appreciated...
Thanks
~Radd
Raddman is offline   Reply With Quote
Old 01-05-2007, 09:22 PM   #2 (permalink)
View sambojoho's Photo Gallery
I would replace the battery if it is cranking slow. That is exactly how it started on my 02 last year. After about 2 weeks of that it finally died. You can probably get a battery for around $50, so it's good cheap preventative maintenance anyway.
sambojoho is offline   Reply With Quote
Old 01-06-2007, 12:17 AM   #3 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
replace it, 03 means probally built in 02 now its 07 so your talking 5 years already. its about time for it to die.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-06-2007, 06:51 AM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
get a redtop from optima...
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 01-06-2007, 10:38 AM   #5 (permalink)
Gameroom cash: $302587
View titosalvador's Photo Gallery
Raddman, this might help you, http://www.autobatteries.com/, it is all about car batteries, Good Luck.
titosalvador is offline   Reply With Quote
Old 01-06-2007, 10:38 AM   #6 (permalink)
All-Trac Guru
D
$$$ those puppies are very pricey batteries.
Does your engine make this sound when cold? montreal 1st Generation (2003-2008) 52 12-29-2007 07:56 AM
88 Corolla battery drain. albertmdh Archived Corolla threads 20 02-11-2006 09:29 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
Non factory alarm draining battery? 03 CE Corolla... Please help latstar Archived Corolla threads 3 01-28-2005 07:11 PM
Hids for my 03 corolla? lumsifu Archived Corolla threads 5 07-23-2004 08:22 AM
