I am going to be doing this later this year.
To make it a bolt up without modding it
YOu need the rear subframe and all the arms that go with it with the rear wheel hubs. Along with ebrake cables for it and the brake porportioning block off the firewall of a gts so that the brakes work properly.
Along with a new set of pads rotors and calipers (I suggest flex lines too).
But suggestion is not to get them if you don't use them hard alot, if you plan to auto x the car or drive like a crazy bastard all the time then they should be good. But I've heard about the rear calipers being a pain from the guys who have gts', also heard from alot of people that the disc brake ebrake SUCKS!
