Originally Posted by 89corolla4wd
what i meant is that i corrected the distributor issue. Now the car is smoking. Cant really tell if its water or oil. i know water is white and oil smoke is bluish but its hard to tell. So now i checked the compression and its 180,180,165,190. its greater than 10 percent difference . i'm thinking it means number 3 cylinder is the culprit. I was just asking can anything else cause excessive smoke coming from the tail pipe such as water leaking into the throttle body from the coolant passages in the throttle body some cars have. Not sure about the corolla.
yes the water from the throttle body can cause smoke... are you consuming any oil? you probally have a bad pistion ring on cylinder 3 and or the new headgasket got pinched there and is still leaking into the cylinder. pull the number 3 spark plug and look to see if it has oil on it, or is wet from coolant
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
