Re: Valve cover gasket set on 4AGE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 09:41 PM   #1 (permalink)
View Kevs Toy's Photo Gallery
AE86 Re: Valve cover gasket set on 4AGE
Ok, gonna call the Toyota dealership about ordering a valve cover gasket set for my gt-s. When I tuned it up I had quite a bit of oil on the plugs. More than likely it was from the tube seals going around the plug holes I'm guessing. What I want to know is if I order a valve cover set, will this include the o rings I need to replace or are they different? The inside of the valve cover it very hollow when you look in, compared to a dsm or honda engine anyway. I know with those you just boughte the valve cover gasket and the 4 o rings that go around the spark plug holes. Do I need anything else for the 4age?
Kevs Toy is offline   Reply With Quote
Old 01-16-2007, 01:31 AM   #2 (permalink)
operation boro thunder
View project trueno's Photo Gallery
^which 4AGE are you refering to? The stock 16V?
If so, there are no seals or O-rings around the spark plugs. There are no spark plug tubes either, like the 4AF/4AFE. If there is oil in your spark plug valley, its either the valve cover gaskets, or the oil cap seal.
Since the 16V 4AG valve covers are 2 piece, you need two seals. They're both the exact same shape. Parts person should be smart enough to sell you a pair.
Now if you're refering to the 20V 4AG, then its a different story.
project trueno is offline   Reply With Quote
Old 01-16-2007, 10:18 PM   #3 (permalink)
Ya, stock 16v and thank you for the info project trueno. Gonna call the dealership tomorrow. May order the oil cap seal just to be safe as well
Old 01-17-2007, 03:22 AM   #4 (permalink)
schn0354's Avatar
View schn0354's Photo Gallery
I assume you have oil on the ceramic part of the spark plug, not the electrode tip (much bigger problem).
schn0354 is offline   Reply With Quote
Old 01-17-2007, 03:21 PM   #5 (permalink)
View Mr.X's Photo Gallery
re
CT sells these VC kits at a fraction of the price...
Mr.X is offline   Reply With Quote
determining oil leak: valve cover or head gasket? Camry LE 94 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-28-2006 03:58 PM
valve seals maybe not valve cover gasket Tercel Lady Tercel, Paseo, Starlet, and Sera Forum 5 03-23-2006 08:39 AM
valve cover gasket question Tercel Lady Tercel, Paseo, Starlet, and Sera Forum 13 03-13-2006 11:14 AM
Introducing myself and my first question - valve cover gasket hooRAH Camry & Solara Lounge 7 02-10-2006 01:48 PM
Valve Cover Estimate ArmyofOne Camry & Solara Lounge 5 10-02-2004 11:15 PM
