91 wagon pops out of 5th gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2007, 10:17 AM   #1 (permalink)
View rickrolla's Photo Gallery
Canada 91 wagon pops out of 5th gear
My 91 wagon (2 wheel drive, 440,000 km) pops out of 5th gear when cruising on the highway. Any ideas of the cure?
Richrolla
91 Corolla Wagon 440,000km
92 Previa 5Speed 328,000km
rickrolla is offline   Reply With Quote
Old 01-16-2007, 10:55 AM   #2 (permalink)
View prophase's Photo Gallery
Funny I had an 86 honda that did that and found it was the throw out bearing.
Manual tranny though!
05 Corolla LE
07 Subaru 2.5i wagon - modded
prophase is offline   Reply With Quote
Old 01-16-2007, 05:04 PM   #3 (permalink)
View Beemik's Photo Gallery
I am having some problems with shifting and that doesn't relate to your problem but talking to some people about trany issues i found that one fella who had the same problem as you wa sayin it was the syncros in the trany. do you get grinding puting it into reverse? because that is another sign of bad syncros(from what i hear). and i dont mean your typical 'clunk' going into reverse i mean even a slight 'grr..grr'. I dont want to disappoint but if it is your syncros its time for a rebuild or anew trany, and with 440k on a 91 the cost would sound far to much. $1100-$1600 including insall
Beemik is offline   Reply With Quote
Old 01-16-2007, 05:25 PM   #4 (permalink)
Sexy Run
AE92_GTS88's Avatar
View AE92_GTS88's Photo Gallery
ehh I'll rather just pay 300 for a used tranny and istalling it myself rather than pay that much...
jDm tOIt AIIIIGHT!
Jesus I suck . I apologize for this.
AE92_GTS88 is offline   Reply With Quote
Old 01-16-2007, 07:50 PM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Its possible that it is the engine mounts causing this, that happened to a friend of mine (he made me change them) so check them first or as said is could be the gearbox. Second hand gearboxes should be cheap.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 01-17-2007, 08:03 AM   #6 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
Richrolla
could be throw out bearing (release bearing) as prophase said. I think he thinks your tranny is an auto for some reason. P.S. make sure your getting the car all the way in fifth gear
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-17-2007, 08:10 AM   #7 (permalink)
Canada
I'll check the motor mounts when it thaws out (-25 this morning) as the shift lever moves when I step on the gas. There is no real grinding when shifting into reverse so hopefully I don't have to change the transmission (I have a spare in the yard). Has anyone changed the shift cables?
Thanks
Rickrolla
Old 01-17-2007, 08:15 AM   #8 (permalink)
All-Trac Guru
yea but the shifter cables dont move while the car is in gear, so i dont see why they would be a culprit here. how bout that throw out bearing?
Old 01-17-2007, 08:40 PM   #9 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
[quote=rickrolla]My 91 wagon (2 wheel drive, 440,000 km) pops out of 5th gear when cruising on the highway. Any ideas of the cure?
Cure=Big Rubberband
diver9000 is offline   Reply With Quote
Old 01-18-2007, 03:16 PM   #10 (permalink)
Amber's Avatar
View Amber's Photo Gallery
Had that happen in an 84 Celica. It was due to wear on the 5th gear teeth. The wear created an angle that would push the gears apart with a load. It wasn't cheap to fix.
2004 Corolla LE - 5 speed, leather, sunroof, spoiler, fog lights, alloy wheels
600 Mile Club - Founding Member
My FD - 335 hp - ~2800 lbs with me in it!
Amber is offline   Reply With Quote
91 Corolla Wagon Kman General Discussion 2 10-26-2004 03:44 PM
Toyota Corolla 91 stuck at 3rd gear????? kkeennyy Archived Corolla threads 5 12-10-2003 01:06 AM
91 V6 Wagon Body Kit advice HELP!! Stark77 1st & 2nd Generation (1983–1986 & 1987-1991) 9 04-29-2002 10:02 AM
