E-brake weak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2007, 05:50 PM   #1 (permalink)
View DarkNinja75's Photo Gallery
E-brake weak
I'm not sure how much emergency brakes are supposed to stop your car, but pulling mine all the way up only gradually brings it to a stop. I was under the impression that pulling it all the way was supposed to lock your rear tires. Is it ok as it is, or should it be tight enough to lock the tires?
DarkNinja75 is offline   Reply With Quote
Old 01-17-2007, 06:12 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Should be able to lock the rears if going slow ie 50-60km/h
You can adjust them in the car, just have to take the interior off around the lever.
Loosen the nuts and pull some more cable through then thghten them again, should only have about 4-5 click before its on.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 01-17-2007, 07:06 PM   #3 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $489401
View falnfenix's Photo Gallery
that, or the shoes/pads on the ebrake need to be replaced.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 01-17-2007, 10:38 PM   #4 (permalink)
Considering the previous owner took terrible care of this car, and I didn't know the ebrake has its own shoes and pads, that might be it. I think I'll try adjusting it first though.
Old 01-18-2007, 08:49 AM   #5 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
the e-brake doesnt have its own shoes or pads. The e-brake is connected to the rear brakes of the car (whether their drum or disc). The e-brake then manually using a cable pulls the shoes or pads against the drum or disc to slow the car down.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-18-2007, 08:59 AM   #6 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
see, i'm thinking in Chevy terms. a few chevy vehicles DO have their own ebrake, separate from the rest of the brakes.
ಠ_ಠ
IIM - Ksport Procomp Big Brake Kits - 8 PISTON!! ImageInMotion Supporting Vendor Sales 8 07-08-2008 12:21 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
Brake Problem Babar Introduce Yourself Here 0 10-28-2006 02:52 AM
