Antifreeze/coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2007, 10:00 PM   #1 (permalink)
View goooopher's Photo Gallery
Antifreeze/coolant
Over the past months the coolant has needed to be filled up to full.. There is not antifreeze in my driveway, and the exhaust smells the same way it did before this problem has been occuring...jw if anyone had this same issue...i was under the hood a few ago just seeing how shit was and bc i needed to see how i was going to have to get at 2 bolts on my exhaust which has been leaking. I found a small hole at the bottom of the radiator where u can drain the coolant...there was a small amount of coolant at the end...i figure this was where the coolant was leaking, so i turned the little "valve" very tight so that hopefully it closed off the opeining...if this was not the cause...any idea where this coolant could be leaking to?
goooopher is offline   Reply With Quote
Old 01-21-2007, 10:52 PM   #2 (permalink)
View splavin90's Photo Gallery
if you have a blown head gasket it would burn up water when you drive, and steam would come out of the exhuast.
-and your oil may look like chocolate milk.
do a compression test to test if you have a leak.
splavin90 is offline   Reply With Quote
Old 01-22-2007, 05:24 PM   #3 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Since you did find a leak, no matter how small it was, what I would do is fill the coolant reservoir to th high level and watch it for a few days to see if you have solved the problem.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 01-22-2007, 06:12 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
Sounds like you have found the leak. If it turns out that it is somewhere else, a shop can do a pressure test on your coolent system. This should be cheap and will quickly show you where the problem is.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Red or green collant ? em_ Camry & Solara Lounge 42 11-10-2007 07:03 PM
Antifreeze/Coolant for Lexus/Toyota BOWTIE 3 General Discussion 5 12-12-2006 09:46 AM
Engine Cleaning, Lotsa Questions. kf4zra Camry & Solara Lounge 13 12-30-2004 12:18 AM
2000 Camry General Maintenance Questions cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-21-2004 12:57 PM
