Pulling Crankshaft pulley off of a 1zzfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2007, 11:35 PM   #1 (permalink)
View Odncr's Photo Gallery
Hi everyone,
I'm trying to get to the front main seal because I've noticed a pretty bad leak but only when I accelerate hard. I was wondering if anyone knew the bolt size or the thread size; pitch of the bolts needed to screw into the crankpulley so i can pull it off the crankshaft.
Thanks.
Odncr is offline   Reply With Quote
Old 01-23-2007, 11:53 AM   #2 (permalink)
bump
Old 01-26-2007, 04:34 PM   #3 (permalink)
bump
Old 01-26-2007, 06:12 PM   #4 (permalink)
View toyotechwv's Photo Gallery
Originally Posted by Odncr
Hi everyone,
Thanks.
The head of the bolt is 19mm. If you unscrew the bolt about halfway you can use it to slide off the pulley. Put both thumbs on the bolt head and grasp the sides of the pulley and pull. If it doesn't slide off after several attempts, spray some penetrant (PB Blaster) into the slot between the crankshaft and the pulley and retry. The pulley should slide freely but may have some rust build up preventing this.
toyotechwv is offline   Reply With Quote
Old 01-29-2007, 08:48 AM   #5 (permalink)
View tashirosgt's Photo Gallery
Pehaps he meant the service bolts that screw into the body of the pulley when you use a "harmonic balancer" puller on it. Will he need such a puller?
tashirosgt is offline   Reply With Quote
Old 01-29-2007, 10:21 AM   #6 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
thats what he means, and since he's asking i think he does need to use the puller. i have no idea what size bolts those are.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-29-2007, 06:01 PM   #7 (permalink)
The puller is not required. The above procedure works fine with no special tools.
Old 01-30-2007, 08:43 AM   #8 (permalink)
On the AE92, the bolts are also used for a special service tool that holds the pulley stilll so the bolt on the the shaft can be unscrewed. I find that it is easier to use an impact wrench to undo the bolt on the shaft since I have never seen this special service tool for sale or rent. Perhaps the 1zzfe pulley is the same way. I agree that getting the pulley off was no problem, but my cars live in a warm, dry climate. Will NY cars be more rusty?
Old 01-30-2007, 09:42 AM   #9 (permalink)
All-Trac Guru
I didnt say it was required!!!! Please read before you quote people.
I assumed since he knew what he was talking about that he might have run into a problem sliding it off. So he did what every smart person does and asked if we could help him find the right size screw so he didnt have to run back and forth between the hardware store and his car trying diffrent sizes.
Hi everyone,
Thanks.
he didnt ask our opinions, or how to get it off. he asked what size screws he would need.
Old 01-30-2007, 10:25 AM   #10 (permalink)
God forbid I try to make it easier. By the time you find bolts, attach the puller, and pull off the pulley you could have it lying in the floor.
Old 01-30-2007, 12:10 PM   #11 (permalink)
All-Trac Guru
if you had something lying in the floor you would have a problem
Old 01-30-2007, 12:58 PM   #12 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Bolt size, I think 8mm thread for the wheel puller holes.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Need advice for crankshaft pulley bolt removal BIG A Camry & Solara Lounge 13 08-13-2011 09:31 AM
HELP~!!!!Removal of Crankshaft pulley bolt undertow29 89-95 Toyota Pickup/Hilux 17 01-28-2007 05:06 AM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 09:20 PM
4th gen 89 gts crankshaft pulley bolt Horseflydf Celica Forum 1 09-16-2004 01:16 AM
