4age head into my 4afe block - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2007, 12:02 AM   #1 (permalink)
View splavin90's Photo Gallery
so if i get a 4age head can i put it on my engine? i know that the firing order of the FE is something like 1432, and the firing order of the 4age head is 1234.
can i just put the 4afe camshaft in the 4age head?
splavin90 is offline   Reply With Quote
Old 01-23-2007, 12:34 AM   #2 (permalink)
big_fella6699's Avatar
View big_fella6699's Photo Gallery
im goin out on a limb here coz i havent done the swap myself but by the sounds of it u would have 2 change the ecu, coil, distributor, exhaust manifold, intake manifold, fan belt (coz the fe cams fun off each other, while the ge cams run independantly from the belt), fuel lines etc.... like i said, im not 100% but thats just what it looks like 2 me. oh and no, i dnt think u will be able 2 fit the 4age camshafts in the 4afe head as they have different intake angles, and a different cam drive assembly.
1988 ae95 corolla - extractors, pod filter - SOLD.
1986 mazda 929 turbo - 2.5" catback, boost cont, bov - DRIVING (for sale).
19** ke70 corolla, chopped springs all round, welded diff, more 2 come... - DRIVING.
big_fella6699 is offline   Reply With Quote
Old 01-23-2007, 12:39 AM   #3 (permalink)
thanks a lot.
Old 01-23-2007, 01:59 AM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
cheaper and easier to get a whole 4AGE.
Old 01-23-2007, 05:23 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I wouldn't say cheaper... since you can get a head for $50 at a wrecker.
I still have no idea if this will give a power gain or not, I doubt it since the power difference in a 4age big port and a 4afe isn't really all that different. With the pistions being different and not being able to get the rpm of the 4age due to the weaker crank...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 01-23-2007, 08:41 AM   #6 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
4afe block cant handle the 4age head, its like having sex with a whore, it works out for a while, and then she's gone faster than you can snap your fingers.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-23-2007, 09:26 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
the block can handle it no problem. 4a block... thats what they share
I've heard of a 4afe crank breaking before. But I've hit 8000 rpm with mine accidentally before. Also used to take it to 7000 rpm all the time, so have a couple other people in here and their cranks didn't break.
Old 01-23-2007, 10:00 AM   #8 (permalink)
Gameroom cash: $134355
uh...... what?
the 4afe with smaller internals actually shares all sizes with the early 4age..... the crank itself isn't forged (like the 4age) nor balanced as well.... but that shouldn't be a problem if you keep the stock 4afe harmonic balancer......
HOWEVER...... i would just suggest finding a complete 4age smallport.....
Old 01-23-2007, 10:59 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
My harmonic balancer is exactly the same as the 4A-GE has.... and it was stock on my 4A-F
Yes, and the newer 4A-FE with the newer 4A-GE's
Old 01-23-2007, 11:08 AM   #10 (permalink)
Vroom?
freakinbox's Avatar
so my engine shares connecting rods with the early 4age?
Pistons are different?
and cranks not forged which I knew, not as good for high rpm
Old 01-23-2007, 11:31 AM   #11 (permalink)
...... so your 4afe didn't have a harmonic balancer? just a crank pulley?
4ag's don't have balancers.....
Old 01-23-2007, 12:42 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
well, it does have a small rubber ring that separates the outer and inner circumferences, however, took a look at a buddies older 4A-GE and it had the same pulley. Local 4A-FE's have a much heavier pulley.
Old 01-23-2007, 02:47 PM   #13 (permalink)
Bitter's Avatar
he'll need new pistons too, the 4afe pistons are dished.
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-23-2010 11:26 PM
1991 4AFE head to 1997 4AFE block silkydraws Archived Corolla threads 6 09-18-2005 09:39 PM
G head on 4AF block? Punisher Archived Corolla threads 23 03-03-2004 10:07 AM
