My mother has a 96 DX corolla. It has 55K miles and has never had any problems. I drove it a couple of days ago and noticed a vibration when accellerating hard in first or second gear. I thought it might be a bad inner CV joint. I called the local
toyota dealer, and mentioned the problem, they said it could be the CV.. and I should bring it by for them to check..
It just so happens, my mother took the car by the same dealer. The diagnostic receipt indicated the fulid was dirty, contaminated (I did see a little something on the end of the dipstick).. and the vib was internal to the trans. And they told her it needs a new trans
2800bucks.
I took it to a local trans shop I used to work at about 20years ago and checked the inner CV joint on the passenger side,, it (or the bearing is toast). Dropped the transmission pan,, and the inside of the trans looked fine.
So,, the question is,, does the bearing require the trans removal to replace? Is it separate from the CV? and what is normally the cost involved in the replacement of the bearing?
Any body know a good chilton or repair manual (other than the factory one) that provides good info on this repair??
thanks
