wheel bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2007, 03:20 PM   #1 (permalink)
View bklahl's Photo Gallery
wheel bearings
Can anyone tell me how to change the wheel bearings in my 2002 Toyota Corolla S. I would appreciate any help you can give.
Thanks
Bill
bklahl is offline   Reply With Quote
Old 01-26-2007, 03:58 PM   #2 (permalink)
View newbie212's Photo Gallery
Bill,
From the sounds of it, you're just guessing that its the wheel bearings since I read your last posts about ur strut and axle install.. Double check everything that you did.. Did you run into any problems with the axle installation? A wheel bearing can go bad but its not too likely if you never had any problems before the installation with the humming noise.
newbie212 is offline   Reply With Quote
Old 01-26-2007, 05:45 PM   #3 (permalink)
Newbie212
I used aftermarket shafts and they were not exactly the same as the oem. One side the cotter pin on the shaft nut is right next to the axel nut . the other side is about a 1/4 inch from the axel nut. the only difference the parts store wanted to know is if it was ABS or not.
Toyota could not tell me and I am only going bythe fact that no ABS light comes on when you start the car(no dummy light). how tight shold the axel nut be(torque)
Thanks
Old 01-26-2007, 11:28 PM   #4 (permalink)
Was there any resistance when you put the axle on? Did you make sure that the splines lined up? Does the humming get louder as the car goes faster? Could be your wheel bearing.. If it is, you need a press to get the old bearing out and the new one in..
Old 01-27-2007, 11:02 AM   #5 (permalink)
wheel bearing
newbie212
the shafts went on very easily no resistance just on tap from my rubber mallet and they were snug. it does get louder with speed and really makes noise on decelleration. at one point when turning the noise will stop, but just for that perfect point in turning.
Old 01-27-2007, 01:44 PM   #6 (permalink)
Originally Posted by bklahl
newbie212
Almost 100% its your wheel bearing.. If the noise goes away when you turn the wheel then thats it... Take the hub off and have a machine shop press the new bearing in.. New bearings are really cheap.. Should fix your problem.. Hope this helps
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 01:17 AM
About rear wheel hubs n bearings soccerman58 Tercel, Paseo, Starlet, and Sera Forum 30 10-05-2005 09:03 AM
where's the best place to buy wheel bearings? baartman Archived Corolla threads 4 03-09-2003 11:10 AM
