2000 JDM Corolla Idle Problem... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2007, 03:49 PM   #1 (permalink)
View Spud's Photo Gallery
Hey guys!!! Ive noticed recently that my JDM Corolla sedan idles roughly.Wether or not the A/C is on.The vibration can be felt by everyone in the cabin of the car and I feel it through the steering wheel and brake pedal.Ive have changed 2 engine mounts, had the plug wires, plugs and distributor checked and everything is fine according to my mechanic.Last week I tried some injector cleaner but it hasnt seemed to work.I have also checked the PCV valve and it isnt blocked.What else could it be??? I am almost at my wits end as the rough idling is getting on my nerves!!!! Ive also had the timing checked and it is okay as well. Any help here would be greatly appreciated.My car if you guys remember is a JDM Corolla sedan equipped with the 5AFE engine...here are a couple of pics....
If perfection could be attained it would not be worth having.
Spud is offline   Reply With Quote
Old 01-27-2007, 04:36 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Is your idle RPM higher or lower than before the vibration started?
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 01-29-2007, 05:59 AM   #3 (permalink)
Im not sure.I havent noticed any drop in rpm.....hhhmm....I wonder if the engine needs a tune ot something....what do you think??
Old 01-29-2007, 09:13 AM   #4 (permalink)
BLACK's Avatar
View BLACK's Photo Gallery
When last u had it tuned?? Did your mechanic check the ISC ( Idle Speed Control ) valve??
BLACK is offline   Reply With Quote
Old 01-29-2007, 10:19 AM   #5 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
what does the engine idle at? if its below 750rpm could be your problem. should idle at 750rpm and 800rpm with headlights on.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-31-2007, 08:59 PM   #6 (permalink)
Idle speed was 800 rpm....Ive never had the engine tuned.
Another clue to rough idle problem (pics) damone Supra Forum 15 02-21-2005 11:22 AM
high idle problem 93twinstick General Discussion 4 11-04-2004 12:50 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
94 corolla rattle idle problem rmiller Archived Corolla threads 4 02-20-2004 03:30 AM
