Sluggish when cold / High speed missfire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2007, 02:29 PM   #1 (permalink)
View Forester430's Photo Gallery
I'd really appreciate any possible help on this.
I have a '95 Corolla, 1.8L, with 150,000 miles. It seems to start and run fine at idle but is sluggish and jerky when taking off at first when the engine is cold (outside air temp has no effect). Once warmed up it seems to run fine, except that maybe once every 2-3 miles (worse under a load, uphill, etc...) at highway speeds it will missfire or something. It jerks pretty hard but just for an instant. Replaced plugs, wires, distributer cap, rotor. Seems to be 90% better but not cured. Still doing the same things just not as bad or as often. That part doesn't make sense to me. Any suggestions?
Thanks!
Forester430 is offline   Reply With Quote
Old 01-31-2007, 08:50 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
check timing, and coolant level (could have a headgasket leak leaking into a cylinder, antifreeze doesnt explode causing a misfire).
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-31-2007, 09:15 PM   #3 (permalink)
View hishamzz's Photo Gallery
check fuel injectors.. might be clogged and warm temperature usually thins the clog a bit but then when more fuel is required.. it might not be able to supply.. just might be your prob..
Zz
hishamzz is offline   Reply With Quote
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
High idle when cold 89yotatruck 89-95 Toyota Pickup/Hilux 4 12-20-2006 09:40 PM
High Speed Amphibian? EKam General Discussion 9 09-10-2003 10:20 PM
High idle rpm when cold griptite Hardcore Tech and Competition 1 05-07-2003 02:38 AM
High Speed Troubles TigerSilhouette General Discussion 10 12-28-2002 10:25 PM
