Oil leaking on pedals from behind dash?? help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2007, 09:47 PM   #1 (permalink)
jfults2000's Avatar
View jfults2000's Photo Gallery
I have a '90 corolla sedan with about 133k miles on it. On a recent trip to Nashville my noticed there was an oil substance dripping from behind the dash onto the petals and her feet. Initially I thought break fluid but it's motor oil. Can someone please explain to me if there is an oil line running to the gauge cluster? Oil pressure?? What would cause it to leak?? Has anyone else ever experienced this?? How easy of a fix is it??
It only drips when the engine is running and there is oil pressure it seems.
Any help is appreciated.
-Josh
jfults2000 is offline   Reply With Quote
Old 01-30-2007, 09:58 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
There could have been a mechanical oil pressure gauge in there at some point I guess.
Pull the dash apart and see where it's coming from.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 01-30-2007, 10:00 PM   #3 (permalink)
jfults2000's Avatar
Unfortunately i'm out of town the rest of the week. The car is at the airport waiting for me. I am posting here to hopefully get an idea as to what i'm up against. Thanks.
Old 01-30-2007, 10:26 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
clutch fluid would be my guess
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 01-30-2007, 10:35 PM   #5 (permalink)
jfults2000's Avatar
Auto trans... thanks for the thought though...
Old 01-31-2007, 12:48 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
A/c?
Old 01-31-2007, 02:22 AM   #7 (permalink)
View 94_Rolla_Guy's Photo Gallery
this will sound weird but listen.. its probably transmission fluid coming up the speedometer cable there is some seal on the lower end of the cable that if it goes the trans fluid will creap up the speedo cable. take out the cluster and take a look at the cable..
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 01-31-2007, 07:12 AM   #8 (permalink)
jfults2000's Avatar
Thanks I will look into that... The fluid coming out is motor oil though not the red dexron III trans fluid....
Keep the ideas coming guys I appreciate it.
Old 01-31-2007, 08:44 AM   #9 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
thats what its always been in my case.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 01-31-2007, 09:09 AM   #10 (permalink)
jfults2000's Avatar
Ok i will definately check it out then... any comments on how to replace the seal or where the seal is?? thanks
-Josh
Old 01-31-2007, 10:42 AM   #11 (permalink)
All-Trac Guru
-Josh
i replaced the whole cable. i know you can use oil pan liquid gasket. there are two parts of the cable. they screw together. thats where the seal is.
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Reset Oil Replacement Reminder dash light Mel72349 1st Generation (2000–2006) 4 01-26-2010 04:41 PM
stock oil cooler leaking on 5sfe DailyDriveCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 12 07-07-2005 12:14 AM
How do you pinpoint oil leaking for 96' Camry v6? shanzhu1 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-10-2005 03:54 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
