99 Headlights will not shut off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2007, 09:15 PM   #1 (permalink)
View tim330i's Photo Gallery
My sisters 99 corolla headlights will not shut off when the car is turned off.
- The parking brake light is always on. I tried grounding this and it still would not turn off.
- The DRL don't turn on (possibly because of the e-brake issue)
- The headlights do not come on automatically
- If you turn the headlights on with the stalk they turn on fine, but turning the stalk off will not turn them off. I just (10 min ago) replaced the stalk so that isn't the issue.
Thank you in advance!
Tim
tim330i is offline   Reply With Quote
Old 02-05-2007, 10:07 PM   #2 (permalink)
Update - I figured out the ebrake light is on because she is low on brake fluid so that point can be taking out of the mess.
Tim
Old 02-05-2007, 10:34 PM   #3 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
Tim
so then you have to disconnect the battery for the lights to turn off?
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 02-05-2007, 10:55 PM   #4 (permalink)
Correct.
Old 02-05-2007, 11:46 PM   #5 (permalink)
All-Trac Guru
possible bad relay for the auto lights causing them to stay on.
Old 02-05-2007, 11:50 PM   #6 (permalink)
Where is the relay and how do I test it?
Thanks,
Tim
Old 02-07-2007, 02:19 AM   #7 (permalink)
Kliddybaba!
fistofmeat's Avatar
View fistofmeat's Photo Gallery
does the car have power locks/keyless entry? on some cars i've seen that the lights stay on after you turn them off until you lock the car w/ the remote. also, i don't think the lights are supposed to come on automatically, only when you use the switch but i could be wrong...
Originally Posted by REN69
OMGWTFBBQ!!! he must have typed it on his blackberry.
"Whenever cannibals are on the brink of starvation, Heaven, in its infinite mercy, sends them a fat missionary."
-Oscar Wilde
fistofmeat is offline   Reply With Quote
Old 02-07-2007, 10:24 AM   #8 (permalink)
View newbie212's Photo Gallery
The headlights are supposed to come on automatically.. Check your relay... I think its next to the fuse box in the engine bay.. I'm not sure..
newbie212 is offline   Reply With Quote
Old 02-07-2007, 12:31 PM   #9 (permalink)
It does have power locks but not keyless entry so I don't think that is it.
Tim
Old 02-07-2007, 12:36 PM   #10 (permalink)
Update -
The DRL are now working (mostly). I guess if you are low on brake fluid, and the brake light is on in the cluster your DRL don't work...which is dumb if you ask me. The DRL don't come on all the time, but if I bang on the relay in the fuse box labeled "head" (or headlights, I can't remember) they will come on. I am going to replace that relay today.
I did more testing and found out that if I turn on ONLY the parking lights (first click on the knob) that they will not shut off either. So there is something that gets switched on with either the parking or headlights that isn't turning off. I need to figure out what that is because it seems to be the source of the problem.
Is there a resistor under the dash for the lights? When I turn them on I can hear something under the dash click, but when I turn them off it doesn't click off (obviously).
Thanks for all the help so far!
Tim
Old 02-07-2007, 01:47 PM   #11 (permalink)
View cheesep's Photo Gallery
There are 2 relays on the BACK of the fuse panel under the dash to the left of the steering column. I know that one is for the rear window defogger because mine failed - it stayed stuck on and nearly melted the fuse panel. I know the other one has something to do with lights but I'd have to check my Haynes when I get home tonight to see specifically what it is for.
It will be very challenging to actually see up into there but if you remove the kick panel under the dash below the steering column you can reach up and feel around for it. You may be able to see part of your hand by looking past the front of the fuse panel accessible by pulling out the little change drawer on the left side of the steering wheel. I recall the two relays being mounted horizontally, side by side. They are both the same part number.
Sorry I don't recall which of the two relays does what but you'll know if you've got the right one because it will likely be burnt brown in the middle from being stuck on and overheating.
The way I found out where they were is that I found a 98 rolla at the auto wreckers with the dash torn apart. The little fuse panel was hanging in the air in plain view. I bought those two relays from the wrecker for $2 (total) and have been living happily ever since! (Shallow life).
cheesep is offline   Reply With Quote
Old 02-07-2007, 02:27 PM   #12 (permalink)
Thanks for the info! I will have to check that out first.
Tim
Old 02-09-2007, 12:29 PM   #13 (permalink)
Sadly I had to tow the car to the dealership The car stopped starting with all sorts of lights on the dash. There doesn't seem to be any clear cut issue so my only thought is to start throwing parts at the problem, which isn't effective and takes time to order them. So I am hoping the dealership can figure this out faster and for a reasonable cost.
Tim
Old 02-10-2007, 10:18 AM   #14 (permalink)
All-Trac Guru
faster... yes, reasonable price no. let us know. a friend just had this problem on saturday but we parked it in the garage and when it the temp outside warmed up it was perfectly fine.
Old 02-10-2007, 12:25 PM   #15 (permalink)
It turns out there was a major ground in the engine harness that was melted. So they patched that up. The also found out the engine temp sensor was bad and the DRL relay is also bad.
I hope nothing else turns out to be bad.
Tim
headlights...shut off when brights are flipped mach9 Pre-88 Toyota Pickup/Hilux 5 01-27-2007 10:06 AM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 09:23 PM
99 Corolla Headlights blue_accord Archived Corolla threads 7 01-02-2007 09:47 PM
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 07:06 PM
replace headlights toyota corolla 99 toyotapad Archived Corolla threads 2 11-13-2004 06:33 PM
