4AGE Waterpumps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2007, 11:52 PM   #1 (permalink)
View EverAE's Photo Gallery
4AGE Waterpumps
Can i use a waterpump from any of the 4age's that were available in north america on my silvertop, or will i have to special order a pump from japan?
EverAE is offline   Reply With Quote
Old 02-07-2007, 12:28 AM   #2 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
from what I've heard, it should be the same as the 4age. The only real change is the head and the ITB's.
diver9000 is offline   Reply With Quote
Old 02-07-2007, 01:37 AM   #3 (permalink)
operation boro thunder
View project trueno's Photo Gallery
Generally they are interchangable, because the bolt patterning is the same.
Two issues you might run into are:
1) Waterpump pulley not lining up to the crank pulley
2) Part of the waterpump physical body might interfere with another part.
Issues are very easy to solve though, I'm using a AE86 RWD waterpump on my BT 20V. So in my case I'm using the AE86 waterpump pulley with the waterpump because it lines up to the BT's crank pulley. Also I had to slightly grind/file down an external "ribbing" on the pump body to have better clearance against the timing belt tensioning pulley. Other than that, direct bolt on.
Another way to play is I could've used the front half of the hi-comp/redtop's waterpump (AE92) with the AE92 waterpump pulley because it will also line up and work.
Play around with it and have fun, and go with OEM Toyota waterpumps.
project trueno is offline   Reply With Quote
Old 02-07-2007, 02:23 PM   #4 (permalink)
thanks for the info, i'm going to go to the dealer near me and see how much they'll charge for a new pump, and see if its cheaper then buying the part at cost, and shipping it from a guy on twincam.
Old 02-07-2007, 04:43 PM   #5 (permalink)
diver9000's Avatar
NO!! The dealer cost will probably triple what it would cost you to purchase a waterpump from a local autoparts store....
Old 02-07-2007, 05:27 PM   #6 (permalink)
i want to use gen. toyota parts for any replacements though. ive been told about 180$ CAD (including shipping) for a new silvertop pump and that seems like a pretty good price, what do you guys think?
Old 02-07-2007, 05:38 PM   #7 (permalink)
The TN Member
View punter's Photo Gallery
I think I paid somewhere in the region of $95NZD for my last one, genuine toyota, including shipping. But hey different markets and all that.
Toyota parts are very good quality, better than most aftermarket parts.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
4AGE and 4AGE 20 valves for sale.. nixem311 Car Parts for Sale 11 08-26-2010 06:07 PM
supr injectors in 4age with 4age injector resistor box. Corollenertia Archived Corolla threads 0 07-08-2005 10:04 PM
