Synthetic oil - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2007, 04:16 PM   #16 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
If a mechanic said that I'd go to someone else.
Old 02-08-2007, 05:00 PM   #17 (permalink)
View darcsyde's Photo Gallery
i've used royal purple as well
darcsyde is offline   Reply With Quote
Old 02-08-2007, 05:31 PM   #18 (permalink)
View htoler's Photo Gallery
he didn't say it would hurt the engine just that there is no way it could protect the engine for 25 thousand miles between oil changes he said it was because of the heating and cooling of the engine and the production of moisture from that. for the reason it would not last that long.. he said 7`500 miles would be really pushing it..if a synthetic was used..
htoler is offline   Reply With Quote
Old 02-08-2007, 05:43 PM   #19 (permalink)
View tnmk's Photo Gallery
His opinion. not based on any facts what-so-ever. Go to bobistheoilguy.com and read some of the results of used oil analisys. There are many that are over 10k and the oil is still fine. Though you won't find many over the 15k mark, they are there.
In other cases where people use premium air filters and by-pass oil filter systems there are people that go over 100k doing periodoc UOA's.
tnmk is offline   Reply With Quote
Old 02-08-2007, 05:59 PM   #20 (permalink)
Resident asshole
Flashmn's Avatar
I change the oils every 10,000km on the benz. Service states 15000km.. I think its too much, why risk it.
Ok so did drive 38000km on some shit oils in my nissan. They stank to high heaven when I took them out. No other damage was present... Still, I dont think its that good.
Old 02-08-2007, 06:08 PM   #21 (permalink)
tnmk how many miled do you go between oil changes??
Old 02-09-2007, 09:54 AM   #22 (permalink)
wantin150's Avatar
View wantin150's Photo Gallery
+1 here. Bad, bad, advice from the "mechanic". There are some situations where synthetics can cause issues (leaks). These are usually on older engines with a sludge problem. The synthetics will "clean" the engine a little and a leak could develop in an area previously blocked by sludge. This is not an oil issue, per se, but an issue that previously existed and was brought to attention by the synthetic oil. Some brands of synthetcis seemto be "consumed" more by some engines.
The bottom line is: Run what you want to. Change every 5-7.5k. If you want to extend OCI's, get UOA's done until you find the max life of that oil for that engine.
2003 XRS - Indigo Ink Pearl
K&N Typhoon SR
Magnaflow Cat back Exhaust
Energy Suspension Motor Mounts
Speed Source Cable / Shifter Base Bushings
wantin150 is offline   Reply With Quote
Old 02-09-2007, 11:37 AM   #23 (permalink)
Resident asshole
Flashmn's Avatar
Yeah and even then its a matter of old gaskets, etc. Also older engines burn synthetic oil more, because the oil finds its way past leaky seals to the combustion chamber...
Didnt happen to me and I have a 1990's corolla.
Old 02-09-2007, 01:44 PM   #24 (permalink)
When I used Mobil One once b4 I changed to Amsoil I went about 12,000. Now with the Amsoil I'll go a year which for my family is about 18,000. That's alot of hwy miles.
Cars run great.
Prior to using synthetic I would go 5-6000 on old dino oil. I've never had any oil related probelms.
Many probably think I'm nuts, but I know my cars will still go 200,000 miles easy. I won't keep them longer than that.
Call me new school.
Old 02-09-2007, 08:07 PM   #25 (permalink)
20XRS06's Avatar
View 20XRS06's Photo Gallery
Amsoil 5-30...
http://www.line-man.com/
20XRS06 is offline   Reply With Quote
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
2nd Oil Change to synthetic... netranger6 2nd Generation (2005+) 35 10-09-2005 02:45 AM
72k too late for synthetic oil? Obelix Camry & Solara Lounge 23 04-26-2005 06:46 AM
Chaning to Synthetic Oil on 2002 Camry XLE V6; Question... Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 8 09-11-2002 06:53 PM
