07 S Heater issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2007, 02:41 AM   #1 (permalink)
I'm wierd
Frankenstipe's Avatar
View Frankenstipe's Photo Gallery
07 S Heater issues
Ok this is really starting to piss me off. I rarely use anything but the front and rear defroster because it gets way too damn hot in my car after only a minute, maybe less. I have to keep setting the heat to either the low middle or cold setting. Even with the fan setting on off it still pumps out heat like mad. Any suggestions?
Frankenstipe is offline   Reply With Quote
Old 02-09-2007, 08:08 AM   #2 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $489401
View falnfenix's Photo Gallery
that's not a bad thing. change the temperature to be less hot.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 02-09-2007, 08:11 AM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
if u crank the heat up and turn the knob to OFF u will still have hot air coming in to the car... when the car moves it pushed air through the vents.... just turn the temp down and ull b good
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 02-10-2007, 01:36 AM   #4 (permalink)
I'm wierd
I realize all I have to do is turn the heat down and the fan off. But I live in an area where the defroster needs to be on alot of the time. Just turning the heat down doesn't help because then I have to turn it back up a minute later because the windshield fogs up soo fast since the setting is still set to defrost. So I have to turn the setting to blow out the main air vents and turn the heat down everytime it gets too hot, which is every 30 seconds or soo after I set the heat to hot. If you understood any of that then you understand that this is a real pain in the ass, which is why I'm wondering if there is anyway to fix this heat problem. I don't like having the windows open either.
On an unrelated matter, does anyone know how to disable the panic button on the remote?
Old 02-10-2007, 04:43 AM   #5 (permalink)
View RAILZ01's Photo Gallery
USA
Sounds like normal operation. Most modern cars work that way. If you have air condition turn it on with the defogger fan on low and make sure you don't have the recirculating air switch on. This way your windows will stay clear and you can keep the temp cooler.
RAILZ01 is offline   Reply With Quote
Old 02-10-2007, 07:40 AM   #6 (permalink)
2005ToyotaCorollaS
try using the def/floor setting that always works very good for me.... u get warm air on top and cooler air on botton dunno why it works this way that is just the way mine does...
D
Old 02-10-2007, 09:11 AM   #7 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
roll down the window
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 02-10-2007, 09:15 AM   #8 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
ok, so leave it on full blast but turn the TEMPERATURE down...this isn't a "problem" - it's what we call operator error.
ಠ_ಠ
Old 02-10-2007, 02:54 PM   #9 (permalink)
I'm wierd
Yup...I'm an idiot half the time, the other half I'm just lazy. >_<
Thanks for the help.
Old 02-10-2007, 10:39 PM   #10 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
do yourself a favor. don't blame the car until you consider all possible options.
ಠ_ಠ
Old 02-12-2007, 02:55 PM   #11 (permalink)
07 Corolla
Jonny Steele's Avatar
View Jonny Steele's Photo Gallery
this is the same way with chevy trucks, the air from outside will go through and warm up, then out your vents, the only way around it is to put your position control on vent, or vent plus floor, only these two will work cuz u then have to put your recuculate button on, u can only do this while is os on floor or vent and floor, with that button on, even with the fan off, it wont allow any air from the ouside to come in, thus, no more hot air.
Jonny Steele is offline   Reply With Quote
Steering wheel issues 07 camry LE marichi 5th & 6th Generation (2002-2006 & 2007-2011) 8 01-24-2007 12:54 AM
07' Camry Trunk mat issues anyone? Catrental Camry Hybrid 1 12-21-2006 02:54 PM
07 Camry issues missedtackle 5th & 6th Generation (2002-2006 & 2007-2011) 1 07-21-2006 07:07 AM
22R Cold Mixture Heater? bs1231 Pre-88 Toyota Pickup/Hilux 3 05-09-2006 09:47 AM
Heater Issues ComaSport4x4 2nd Generation (2005+) 9 02-03-2006 05:13 PM
