97 Prizm with abs-pressure bleed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2007, 10:20 AM   #1 (permalink)
View 93ToyCorolla's Photo Gallery
USA 97 Prizm with abs-pressure bleed?
Is there any problem with pressure bleeding the brakes in a 97 1.8L with abs. I have read that certain cars with abs should not be pressure bleed. Thanks!
93ToyCorolla is offline   Reply With Quote
Old 02-11-2007, 07:01 PM   #2 (permalink)
USA How about 97 Corolla 1.8L with ABS
Anyone done a brake pressure bleed on this car?
Old 02-12-2007, 10:32 PM   #3 (permalink)
USA Anyone
done this before.
Old 02-13-2007, 04:19 AM   #4 (permalink)
View RAILZ01's Photo Gallery
USA
I have ABS on my 01 and I've pressure bled the brakes several times with no problems. Where did you read no to pressure bleed?
RAILZ01 is offline   Reply With Quote
Old 02-13-2007, 08:54 PM   #5 (permalink)
USA haynes manual
In reference to normal brake bleeding (pump the pedal, hold) it states if you are working on a Geo Prizm model, this procedure might not completely purge the air from the hydraulic system. A tech 1 tool might be needed to "rehome the pistons".
Old 02-14-2007, 07:24 PM   #6 (permalink)
The TN Member
View punter's Photo Gallery
Alot of manuals have special procedures for ABS cars, but I have never had any problem at all using the normal method on ABS cars, I've done it on my 91 levin about 5 times and its sweet.
So basically just treat it as a non ABS car.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 02-18-2007, 11:29 AM   #7 (permalink)
USA Done it.
Preformed the pressure bleed yesterday. No problems.
Old 02-19-2007, 11:51 AM   #8 (permalink)
blb
View blb's Photo Gallery
As long as you don't let the master cylinder run dry, you will be fine using conventional bleeding methods on an ABS equipped vehicle.
blb is offline   Reply With Quote
Old 08-30-2007, 09:29 PM   #9 (permalink)
correction: I hate Isuzus
InfInIty13X's Avatar
View InfInIty13X's Photo Gallery
I read about that in the Haynes manual but it referred to all Prizm models. So what exactly does the Tech II scan tool do? Why would you want to rehone the cylinder if the master cylinder ran dry?
'96 Geo Prizm base 280k+ miles
'91 Isuzu Impulse RS 130k+ miles (parked with bhg)
InfInIty13X is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
ABS & Tire Pressure Light l_touring_dude Archived Corolla threads 1 11-08-2004 09:59 AM
Ractive Ram Air system. Camry_rider Hardcore Tech and Competition 51 07-23-2004 11:03 AM
